Results 1 to 15 of 15
Thread: weird tire wear problem
    Almost Done Black87GT's Avatar
    Selinsgrove, PA
    526
    Ok, well i bought (4) weld draglites from don aka fast4ord and have them on, and now all the sudden after a couple weeks, the rear drivers side drag radial is wearing different than the rest.. the outside is wearing really bad while the rest of the tire is fine... rest of the tire has quite a bit of tread (for a dr) and the outside i can see tread but cant even feel it, its so bad...
    does this tire need balanced or should i just keep driving around on it??
    Fox/n.
    1. wild animal : a carnivorous animal of the dog family that has a sturdy square body, large cubic inches, a wide RPM range , and comes in many colors. Foxes are found throughout most of the world and hunt alone, mainly at night, relying on cunning and an acute sense of power and acceleration. They feed on mostly small rodents like rats(BBC) , mice (SBC) and snakes(Cobras).
    Tire Wear
    ON THE REAR? SOUNDS LIKE A BAD AXLE BEARING OR A BENT TUBE???? BALANCING IS NOT GONING TO SOLVE A WEAR PROBLEM ON THE OUTER EDGE
    JUNK IT!
    Senior Member SV1000s's Avatar
    Chandler, AZ
    1,532
    and that could also account for the driveline vibration........
    check the tire pressure
    Selinsgrove, PA
    526
    i swear to god its just one thing after another with this ****ing car..
    any way to check if i have a bad axle bearing or bent tube??
    Fox/n.
    Selinsgrove, PA
    526
    ok well i just looked, and it says my drs are supposed to have 40 max psi, so i checked (looked really low) and i was right, they both had 15-18 psi..... so i filled to like 37 each...
    would that have caused the retarded wear??
    Fox/n.
    over inflation causes inner tire wear.
    under inflation causes outer tire wear.
    Selinsgrove, PA
    526
    so tim, that was most likely my problem?
    Fox/n.
    Chandler, AZ
    1,532
    Quote Originally Posted by Black87GT View Post
    both outside edges of the tire will be wearing badly if the tires are under inflated.....in theory
    Selinsgrove, PA
    526
    oh great, only the outer edge is worn.... *gulp*
    Fox/n.
    Chandler, AZ
    1,532
    If I were a betting man, I'd have to say you have a bad axle bearing which is causing the premature tire wear and the vibration. BUT I'm not a mechanic.......... did you ever take the car to a mechanic regarding the vibration issue??
    Selinsgrove, PA
    526
    no because everybody on here just said not to, to just replace the driveshaft...
    axle bearing expensive??
    Fox/n.
    Senior Member White5.0's Avatar
    State College, PA
    3,552
    $12.00 each from latemodel restoration
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Senior Member casper gt's Avatar
    Oct 2007
    creighton pa
    260
    tire wear
    axle bearings would cause inside wear. Id say check to make shure tire is not hitting wheel opening lip especially if old tires were smaller & wearing ok.
    far from a newb!!! INSANELY CRAZY's Avatar
    out in the woods
    4,948
    did they have any kind of wear on them when you bought them? if the wheels were on a previous car that had issues then they may have started to wear on that car. once a tire starts to wear it dont matter what car or where you mount it on the car it will still wear in that same spot even if there's no issue with your car.
    ridin fast,hittin da hills,throwin some dirt
    2003 polaris predator 500
    (wanna ride,just pm me!!!)
  1. Always wear your safety glasses
    By mustang50lx in forum The Bar
    Last Post: 05-21-2014, 08:39 AM
  2. I know, I'm weird...
    By travj31 in forum Pictures & Videos
    Last Post: 07-25-2013, 10:33 AM
  3. Think these guys should maybe wear a helmet?
    By cam303 in forum Pictures & Videos
    Last Post: 07-20-2008, 03:03 PM
  4. vibration and tire wear issue.
    By cc4x4rider in forum General Tech
    Last Post: 01-13-2008, 05:25 PM
  5. airbrush on intake will it wear off?
    By PunisherStang in forum SN95-New Edge
    Last Post: 09-16-2007, 03:20 PM
