Thread: WTB fox TB setup parts
    I am doing teh fox body TB conversion on my car and need the following parts
    Fox TB IAC
    Fox Throttle cable
    Fox Cruise control cable
    Fox throttle cable bracket
    Fox Fuel injector wiring harness side of the TPS sensor
    Fox EGR valve (and a 5\8" cap to block off the EGR port on your header)
    Fox EGR spacer (with Fox TB studs) if not using a '93 Cobra intake or EGR delete plate to mount throttle bracket.
    Fox Vacuum tree (available at 50resto.com like most of these parts)
    Tubing to run from the VC filler neck to the TB PCV tube connection if not using SN95 port
    Thanks in advance
    Member RUSH2112's Avatar
    Hopewell, PA
    754
    I have a stock EGR spacer
    Edelbrock Performer Heads, BBK Ceramic Long Tube Headers, BBK O/R H-Pipe, BBK Cold Air Intake, BBK Strut Tower Brace, Flowmaster American Thunder Cat-Back, FRPP King Cobra Clutch, FRPP 3.73 Gears, FRPP Chrome Cobra Upper/Lower Intake, FRPP Chrome Polished Valve Covers, Chrome Alternator, Ford B303 Cam, Holley Fuel Pressure Regulator, 70mm Edelbrock TB, 75mm Pro-M MAF, #24 Ford Injectors, Crane 1.7 Rockers
    Mt Pleasant
    2,916
    i got some stuff lying around in my garage
    let me know..
    Hopewell, PA
    754
    I have a stock EGR spacer. Let me know if you want it
    I have a stock 87-93 H/O intake with throttle body, EGR spacer, injectors and fuel rails. If interested send me a PM
  1. wtb fox parts!!
    By 91gtlmstang in forum Ford Parts
    Last Post: 08-06-2012, 02:07 PM
  2. WTB: Parts for a 5 lug Fox swap
    By 50Dro in forum Ford Parts
    Last Post: 07-16-2010, 06:58 PM
  3. WTB...Fox parts.
    By ccoyle0103 in forum Ford Parts
    Last Post: 05-18-2010, 08:22 PM
  4. WTB: fox TB parts
    By scott5 in forum Ford Parts
    Last Post: 09-12-2009, 09:22 AM
  5. WTB: T-5 for my 5.0 fox setup
    By onenastytbird in forum Ford Parts
    Last Post: 08-26-2008, 02:46 PM
