Results 1 to 4 of 4
Thread: 1990 honda crx si
    1990 honda crx si
    90 honda crx si-$1,800 w/ Engine below
    -prothane bushing kit
    -prothane trailing arm bushings
    -Front and rear wheel bearings
    -Upper and lower ball joints
    -New tie rod ends
    -Steering rack bushings
    -Front and rear swaybar bushings
    -Front and rear Brembro rotors
    -Front and rear calipers
    -EBD brake pads
    -Goodridge steel braided brake lines
    -E-brake cables
    -Toxico shocks and springs - 1.5" drop
    -Thermal exhaust
    -DC sports header
    -AEM CAI
    -Front and rear strut bars
    -chipped p28 ECU w/ cable to hook to laptop for data logging
    -OBD0 TO OBD1 conversion harness
    -Walbro 255 fuel pump
    -ACT HDSS clutch
    -Engine-D16A6 W/ V-TECH HEAD
    -D16Z6 head
    -ZEX 59300 cam and springs
    -port and polished
    -Competition valve job
    -replaced all seals and gaskets
    -5th gen intake manifold w/ integra throttle body
    -FIC 650cc injectors
    -D16A6 Block -8:1 Compression (built for turbo)
    -SRP pistons (.20 Over)
    -Eagle rods
    -ARP head studs
    -3 layer metal head gasket
    -Balanced and blueprinted
    -Rod and main bearings replaced
    -New oil pump and water pump
    -New engine pulleys and gears for timing belt
    -New timing belt
    -Fidenza 5 bolt cam gear
    -All new engine seals and gaskets
    -100% rebuilt engine
    -has around 8k miles on it
    -Additional parts-Included with car price
    -D16A6 cylinder head
    -Comlete A/C system for crx
    -Prothane shifter bushings
    -Misc. parts that came off car
    Fuwkawee
    5,151
    How about some pix...I have a friend that would maybe be interested...How many miles on the body and what kind of shape?
    17 Ram 1500 Big Horn Hemi
    16 Comp O GT Performance Pack
    if you give me an e-mail address i can send you some but call me if you have any questions (814)943-7953 or (814)414-9367 190k on body the usual rust spots around the quarter panels this car moves for being low compression.
    Fuwkawee
    5,151
    o.k I'll give him your No. he used to have a 91 that had 300,000 on it. and he sold it for $3,000 a few years back.
  1. 1990 Aod
    By HOTMARK7 in forum Ford Vehicles
    Last Post: 11-11-2011, 09:04 PM
  2. 1990 lx
    By fast4ord in forum Ford Vehicles
    Last Post: 08-20-2011, 05:06 PM
  3. 1990 lx/ parts
    By fordfan89 in forum Ford Vehicles
    Last Post: 08-19-2010, 12:49 PM
  4. 1990 LX For Sale
    By steedafied in forum Ford Vehicles
    Last Post: 10-10-2009, 10:32 PM
  5. F/s--1990 Lx 5.0
    Last Post: 09-18-2006, 10:56 PM
