Results 1 to 20 of 30
Thread: heads
    North Hills
    1,229
    heads
    im throwing around the idea of getting my twisted wedge heads fixed and ported, or just fixed and sell them to step up to a set of the R series heads.
    my stock Twisted wedge ones flow 170cc Intake and the R series flow 205cc intakes.
    i know bigger isnt always better, so i dont want to step up to too much of a head for my combo.
    http://www.trickflow.com/product/for...cnc_sbford.asp
    my cam:
    stock bottom end with a ported gt40 lower and cobra upper. made 448rwhp on the trick flow heads at 10psi
    my cam:
    The 170 cc heads dont flow 170 cfm, that the size of the combustion chamber for each set of heads. The 205cc heads have a 205 intake runner volume, and they flow a good bit more than 205 cfm.
    Get your 170cc heads ported by tea or foxlake and you'll make more power than what you'll know what to do with. Rurn the boost up on your current setup & make the extra power, easier & cheaper than doing the heads.
    Good luck!!
    Banned
    329
    The 170 cc heads dont flow 170 cfm, that the Intake runner volume for each set of heads. The 205cc heads have a 205cc intake runner volume, and they flow a good bit more than 205 cfm.
    Get your 170cc heads ported by Domination and you'll make more power than what you'll know what to do with. Rurn the boost up on your current setup & make the extra power, easier & cheaper than doing the heads.
    Good luck!!
    Fixed
    You're going to have a major Piston to Valve clearance issue with the bigger valves of the R heads and the stock pistons, so plan on changing out the pistons as well.
    Quote Originally Posted by Domination View Post
    Fixed
    No offense Jay, but you are not even close to being in the same league as TEA or Fox Lake when it comes to head porting.
    Banned
    329
    Oh, I thought they where doing it by hand. I didn't realize they had a CNC program for his heads.
    and Ron at Fox Lake basically invented his heads.
    Banned
    329
    Well, CNC ported head are Dough, and I'm right down the street from Wright pontiac, soo....
    If you're going to do something, do it right the 1st time!!!
    http://www.foxlakeracing.com/index.p...0Wedge%20Heads
    If your gonna do a T.W. cylinder head try the T.W. 185. The R-Series is a huge mis-match on a stock short block and would most likely require flycutting of the pistons. Give Brian Tooley a call at T.E.A. (1-330-634-2155) Explain your goals to him and I'm sure he will have you pointed in the right direction.
    Banned
    329
    Holy crap, 600$ for a CNC job. That ain't bad!
    What is your labor rate on porting cylinder heads?
    big +1 here too.
    North Hills
    1,229
    what stage are you guys referring to? stage 1 or 2? if i did anything, id have domination fix the heads and send them out to fox lake and probably opt for the
    Stage 1 CNC FAST Port & Upgrade
    Your heads-Our Porting & Valve Spring upgrade
    with new seals, Assembled
    $900 though. ouch!
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    +1. i have stage 1's for now.
    2015 GTPP
    Banned
    329
    50 an hour. I can get a set of aluminum heads decent in around 4-6 hours.
    The 170 cc heads dont flow 170 cfm, that the size of the combustion chamber for each set of heads. The 205cc heads have a 205 combustion chamber, and they flow a good bit more than 205 cfm.
    Good luck!!
    WRONG, 170cc or 205cc is reffering to the port VOLUME, if you had a 205cc combustion chamber your compresson would be like 4:1 with dome pistons, most head have a 60-70cc combustion chamber, and yes the runner volume number is not the amount of flow
    Yes, I was typing fast w/ a baby on my lap, I fixed it.
    Thanks
    I do all my own port work and some for customers, the head on the left is about done, the one on the right is very far away..
    Fox lake is getting my TFS heads and intake this winter. If you want, I can take your heads when I drop mine off.
  1. GT40 3 bar iron heads,NOT P HEADS!
    Last Post: 07-05-2014, 02:14 PM
  2. what heads are these?
    By somethingclever in forum Fox-SN95
    Last Post: 04-11-2010, 05:59 PM
  3. Heads
    By ruger77 in forum Ford Parts
    Last Post: 03-02-2010, 06:48 AM
  4. PI heads
    By Mitternacht in forum SN95-New Edge
    Last Post: 08-11-2007, 02:57 PM
  5. 5.0 heads
    By eddmann55 in forum Ford Parts
    Last Post: 06-23-2007, 10:14 PM
