Results 1 to 10 of 10
Thread: any 200-r4 tranny rebuilders?
    Anyone rebuild 200-r4 trans? Looking to do a mild rebuild on my Buick t-type. should run bottom 11's maybe bump a 10.99 on a perfect pass.
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
    I met Lisa at the PVGP yesterday. If you are in the T-Type or GN crowd you probably know her. Great lady! Her low 9’s T-type is ridiculous. We talked for quite a while - wow is she knowledgeable. Anyway - I asked her about the tranny in her car (if it was a 200-R4 ) and she mentioned it is very expensive to build one that holds the power her car has made. She is running a Turbo 400 if I recall correctly. My point is - have you considered switching to a Turbo 400?
    im friends with her brother. Saw her yesterday. (Yes, I actually took my SS out and put miles on it). She does run a 400. She is also right about serious Ching into a 200-4R as I did with mine. Over $3000 in mine plus another $875 for the PTC converter.
    no need for a 400 at this power level. The 200r properly built
    should hold 500-600 wheel with ease. I just don't want to go all the way out to mid ohio to have a trans done.
    1967 camaro
    86 t-type
    Mar 2017
    Morgantown, WV
    34
    My cousin has a transmission shop in Morgantown, and could most likely build you one any way you want it. Don’t know if that’s any closer for you or not.
    Senior Member Fast Gypsy's Avatar
    Jan 2011
    Allison Park, Pa.
    367
    After going thru a couple of tranny shops, I've settled on J&S in Sharpsburg. I haven't had a problem with my C4 since they rebuilt it. They have been in business for a long time and are great to deal with. Ask for Rege and tell him Mustang Vince recommended him. 412-784-3380
    1988 Mustang 408 W. All Motor New Best 5/5/18 10:15 @ 131 mph.
    1964 Chevy SS Convertible 327 300 HP.
    1964 Chevy SS Hardtop 327 250 HP. Sold 2017.
    1954 Ford Radical Custom Convertible.
    1991 GMC Sierra 1500-SLE 1/2 Ton Reg. Cab Short Bed.
    1930 Model A Sport Coupe Owned Since 1970 Sold 2016.
    Is Transmission Magician in Pittsburgh still around? No direct experience, but understand some time ago they was a go to place for the 200r4 stuff.
    That guy is a space cadet. Stay away from him. He still claims the government stole his ideas blah blah.
    Adam, did you call Vince?
    I talked to vince. didn't want to make that trip if I didn't have 2
    1967 camaro
    86 t-type
    I gotcha.
    You do know I have that spare one here. Like I said though, I have no idea what’s inside it. It was rebuilt. I just don’t know what parts are in it. It was behind a stout small block and has a small converter on it. That’s all I know though.
