Results 1 to 20 of 27
Thread: PI heads
    MPG's, bitch! Mitternacht's Avatar
    Jun 2007
    N. Huntingdon
    1,596
    PI heads
    On my 98 GT, would the PI head swap make that much of a difference? I was looking for Trick flow heads, but it looks like they don't make 'em for the 4.6.
    PI heads port and polished, worth doing?
    Edit: btw I have the Eaton Supercharger and Comp Cams.
    Chris
    2016 Chevrolet Volt
    2010 Jetta TDi Cup Edition
    1964 Lincoln Continental
    And 5 other things that don't run
    Going fast with class Slow01GT's Avatar
    Mars, PA
    1,696
    You already know my opinion. I think it would help you out a lot but i would be careful since the pi heads raise the compression a bit.
    Dennis
    2006 GTO
    Gone but not forgotten
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    5,822
    2019 Colorado ZR2
    Mars, PA
    1,696
    I believe ford racing sells an adapter to use with the pi heads.
    Dennis
    2006 GTO
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    Jun 2007
    N. Huntingdon
    1,596
    I'm just curious if the PI heads are any better or close to aftermarket heads. If that's the case with the ports not aligning, I'll look for another intake.
    Chris
    2016 Chevrolet Volt
    Robinson Twp.
    2,143
    If you were doing it as part of a motor rebuild with different pistons then it would definitely be worth while for the extra flow. But if you're just planning on swapping heads then I don't think it would be good for you because it would increase the compression which would limit the amount of boost you could run.
    2015 Charger Hellcat
    85 GT
    73 F250
    Lifted, 35's, 460 4spd
    Real name = Ray
    Jun 2007
    N. Huntingdon
    1,596
    It will be after a rebuild. I'm planning on a 8:1 compression ratio so I can get plenty of boost and fuel in the cylinders, H-beams, etc.; all of the good stuff I'm saving up to afford.
    Still deciding on a crank. Already got good cams. May need a different manifold. Exhaust is the way I like it. Fuel system can handle the work load. And I'm gonna need a clutch.
    I'm looking at RAM for a clutch. Any good suggestions for the crank?
    Chris
    2016 Chevrolet Volt
    Mars, PA
    1,696
    I would just go with a 03/04 cobra crank since they are forged. Thats what VT and many others use in their built motor combo's. Also, most of the aftermarket heads out there are just ported factory PI's.
    Dennis
    2006 GTO
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    3,499
    Trick Flow has something for ya...
    http://www.trickflow.com/product/man...i_51800002.asp
    KB 2.6 custom fabbed
    Southern California
    311
    Quote Originally Posted by Troll View Post
    worth it. you would probably pick up about 40 horses, but you better check the ports on the bottom of that Eaton S/C. It's probably non-PI specific. non-PI heads have circular ports and PI have squarish ports. Somebody might sell a transfer plate, but you're not going to see the full benefit of the PI heads with the smaller intake runners on the non-PI Eaton. I don't know how they're put together, but you might be able to get a PI lower manifold if it's a two-piece deal. ???
    I don't know what your using for a lower manifold, or what Eaton you have, but Lightnings came with PI heads.
    5,822
    2019 Colorado ZR2
    5,822
    2019 Colorado ZR2
    Jun 2007
    N. Huntingdon
    1,596
    In fact, I was just researching it and I found out its called the Ford SVO Supercharger kit.
    So I'll need a whole nother supercharger kit when I swap heads. Bummer. That'll cost more money than I have right now.
    Chris
    2016 Chevrolet Volt
    i just took a car i built to the dyno with pi heads on it and it made 480 at the wheels with simple mods...
    From his pictures, it looks like he has the Ford Racing Eaton that is specific to the 96-98 non PI cars.
    ford makes the adapter kit to make it work with Pi headed cars...
    Jun 2007
    N. Huntingdon
    1,596
    Would you happen to have a link to it?
    Chris
    2016 Chevrolet Volt
    5,822
    2019 Colorado ZR2
    Southern California
    311
    NA? That is pretty seriuos numbers for PI heads. My truck was making a hair under that supercharged. I had a 6 lb lower and all the bolt ons. It made 600 torque, but i was making 17lbs of boost. I would love to know what you did to make that kinda power on PI heads.
    i can't tell my secrets, but let me tell yah, when its all said and done this car should have 650+ with an s-trim vortech...
    Banned
    329
    So wait a minute. You made 480 with no boost or N20?
  1. GT40 3 bar iron heads,NOT P HEADS!
    By 1badnotch in forum Ford Vehicles
    Last Post: 07-05-2014, 02:14 PM
  2. what heads are these?
    By somethingclever in forum Fox-SN95
    Last Post: 04-11-2010, 05:59 PM
  3. Heads
    By ruger77 in forum Ford Parts
    Last Post: 03-02-2010, 06:48 AM
  4. heads
    By blkp42e in forum Fox-SN95
    Last Post: 09-20-2007, 03:16 PM
  5. 5.0 heads
    By eddmann55 in forum Ford Parts
    Last Post: 06-23-2007, 10:14 PM
