Page 4 of 15 FirstFirst ... 2345614 ... LastLast
Results 61 to 80 of 300
Thread: Project Cocaine
  1. #61
    Banned George C's Avatar
    1,490
    Buddy named it that and cocaine would be cheaper
  2. #62
    Haha - that's great! Thanks for the explanation. "Trophy Wife" would work too...
  3. #63
    1,490
    got around to mounting the wastegate for driverside
    and started working on the driverside downpipe
  4. #64
    If You Wanna thedak's Avatar
    Jul 2008
    DMB
    Damn.....
  5. #65
    2,145
    Quote Originally Posted by George C View Post
    They built my two motors
    As for the other comment, if you want to start shit we can meet up and have a few drinks otherwise keep comments to yourself
    LOL Double standards, got to love them.
    On that note... I am outa here.
  6. #66
    1,490
    You can stay and enjoy the build if you would like to just keep your shitty replies to yourself or until you meet me at the bar
  7. #67
    1,490
    started making some progress on the pass side header
  8. #68
    1,490
    was able to get around to working on the pass side header
  9. #69
    Jan 2010
    170
    Looks awesome!
  10. #70
    1,490
    was also able to make some progress on the pass side dp tonight
  11. #71
    1,490
    engine bay shot
  12. #72
    1,490
  13. #73
    1,490
    well here it is, manual steering rack that bolts in place and everything i used to do the job
    made a 2" long sleeve for the bushings
    i shaved down the one shaft to be able to slide into the trucks column
    rack to rack this mod dropped 14lbs
  14. #74
    Brookline
    2,897
    There is one thing I will never wonder, if another man slid the shaft in 100%
  15. #75
    1,490
    heres teaser of my rear wheels
  16. #76
    1,490
    ok found some tie rods that will work but some modding is required
    first you will need access to a ball joint/ Tie rod reamer
    youll also need to trim the outer and inner tie rod some
  17. #77
    1,490
    Heres my new injectors and driver
  18. #78
    Cocaine would def be cheaper
  19. #79
    Senior Member ebo 4356's Avatar
    Sep 2008
    California, Pa
    194
    Looks great buddy!
    1997 Mustang GT- Sold
    MGW short shifter, Ford Racing 3.73s, JLT ram air intake, mach 1 chin spoiler, Off-road H pipe, Magnaflow Magnapacks, SCT X3 tuner, Full PI swap, steeda underdrive pulleys, 75mm throttle body, professional
    1999 Mustang Gt- On3performance 70mm single turbo, SCT ba2400 mass air meter, upr tubular k frame, upr front coil overs, 42lb injectors, walbro 255, kenne bell bap, pro 5.0 short shifter, 3.73 gears, Modular Head Shop stage 1 cams, SCT X3 tuner. Waiting on dyno tune!
  20. #80
    1,490
    pic of the crank mandrel setup for the belt driven fuel pump, gonna try the 21 tooth pulley and see where the gets me
    started playing with pulley spacing, now just have to cut the mandrel spacers and find a belt
