Results 1 to 3 of 3
Thread: having problems with my 03 cobra
    broke ex-military chargedcobra03's Avatar
    Apr 2011
    Elizabeth PA
    29
    I did a small burnout wasting the tires before I put on the new summer set.
    The car felt great and ran great for the 20 or so minutes I was driving it beforehand.
    After the burnout I pulled out on the highway and got on it and as soon as it hit boost it fell on its face, boost went up and the wideband went to 19+ a/f.
    I looked over the vacuum lines when I got home and do not see anything off and the car and driving out of boost it is running fine.
    I pulled the vac line off the frps and no smell of gas. checked the oil not a sign of gas in the oil. I cleared the code and checked everything from the spark plugs to the MAF and took it for a ride. It ran good. slowly hit boost with no problem.
    About 5 minutes into the ride i tried hitting boost again and it started to do the same thing (boost goes up and a/f goes to 19+ with the car falling on its face).
    It kept on stalling out and thought i would have to be towed. I decided to pull the plug on the frps and it ran fine! So i drove it home not hitting boost and the a/f was normal (13.5-16 while driving normally below 3k).
    Checked the vac line/oil again no smell of gas.
    NO check engine light
    I plugged the frps back in and started it up. idles fine. revved it to make boost (without a load on the motor) and shut it down. The code is back P0193
    Anyone have an idea before i drop 110 for a new frps that may not be the problem?
    3,356
    FRPS symptoms.
    Mark
    LeMans Blue Z06
    Brookline
    2,897
    http://engine-codes.com/p0193.html
    Also sounds similar to other symptoms I've read when the FRPS was on the way out.
  1. 03-04 cobra owners....fan Problems??? I've broke 2 in 5K miles
    By Freakingstang in forum SN95-New Edge
    Last Post: 10-24-2012, 01:49 PM
  2. 04 mach 1 problems
    Last Post: 07-24-2012, 09:44 PM
  3. Just bought a new cobra.. and it has problems
    By Lizik9 in forum SN95-New Edge
    Last Post: 03-21-2012, 02:17 PM
  4. t5 problems???
    Last Post: 05-10-2011, 05:51 PM
  5. 2003 cobra sterring problems
    By regan in forum S197
    Last Post: 03-31-2008, 05:41 PM
Tags for this Thread
