Results 1 to 11 of 11
Thread: 86GT brakes being "spongey"
    2,247
    After pulling my car out for spring my brakes feel as if they're not even there! If I pump them once or twice they work fine. The brake fluid is good and full, could this be my brake booster going bad? HELP!
    Black
    Is the fluid level low? Maybe your rear wheel cylinders are seeping?
    2,247
    Fluid level was a little low but I topped it off and now it is fine. How do I check my rear wheel cylinders?
    Black
    Oct 2010
    300
    just pull a wheel or both and then the drums and if its wet there bad just did 2 in my notch much better
    2,247
    Thanks. I'll check it out in the morning. Are they expensive to replace?
    Black
    Pull the rear wheels and remove the drums. If the wheel cylinders are leaking you'll have a bit of a mess inside the drum. If the fluid level was low it has to be going somewhere. If the wheel cylinders look ok, I'd go thru the whole system checking all the lines, hard and rubber. Get someone to pump the brakes with the car off - and listen and look for leaks. The brakes in my wife's '66 went out once when the master cylinder ( the old single-bowl style ) took a dump, and it can be a very scary thing. It was the first day I had taken the car out after winter hibernation. I was lucky nothing bad happened - I was able to pour fresh fluid in and limp the car home.
    They aren't expensive to replace. Maybe $20 a side tops?
    Good luck - let us know what you find.
    Oct 2010
    300
    no there like 8 to 10 bucks a piece. cant remember just did thiss sat to got bad memory hah
    2,247
    Now that's a price a poor college kid can afford! haha
    Black
    I guess I was thinking about the prices for the '66 rear wheel cylinders - just looked them up & they're around $18. I haven't done any fox repairs in a LONG time!
    Castle Shannon
    1,276
    i have one raybestos unit you can have, yes, only one
    2,247
    Let me check them out and I'll get back to you. I appreciate the offer!
    Black
  1. 03 cobra brakes plus 13" rears
    Last Post: 10-26-2011, 09:52 PM
  2. 15"x9.25" Alumastar 2.0s 6" backspace 4.5" bolt pattern
    By NOVICOUPE in forum Ford Vehicles
    Last Post: 12-23-2010, 10:39 PM
  3. 13" Baer brakes, like new
    Last Post: 08-21-2008, 07:26 PM
  4. Replies: 1
    Last Post: 02-02-2008, 08:37 PM
  5. What makes power brakes "power" ?
    By Troll in forum General Tech
    Last Post: 05-29-2007, 06:04 PM
