Results 1 to 20 of 29
Thread: MT ET Streets radials vs ET Street II
    BUTLER,PA
    161
    Hello, need some help. The kind folks at SLP are installing my Kenne Bell so hoping to be just under 600hp. I ordered up some 10.5 inch Rims with what I thought was going to be MT ET Street Radials (315/35/17) from American Muscle. Well it appears as though they put the MT ET Street II 's on it. Does anyone have any experience with these. Will they work well with the HP I will be making or should I send them back?
    '04 Black Cobra Coupe
    2.2 Kenne Bell, FIPK, Accufab TB and Plenum, Bassani catted X, Borla catback, Head Cooling Mod, LFP HE, SCT custom tune by Terry@Street Lethal Performance
    Complete IRS bushing kit, FLSFC's, BF IRS Brace and Brackets, MM adj tie rod kit, MM aluminum steering rack bushings, Fiore quadrant and ADJ, MGW shifter
    Jun 2007
    2,108
    In that size you are stuck with ET Street II.
    BUTLER,PA
    161
    Quote Originally Posted by ModularMike View Post
    Hmmm, their website shows the regular ET in 315. Do u think the II's will work well? What size do I need if I get the original ET...thanks
    Jun 2007
    2,108
    List of sizes: http://www.mickeythompsontires.com/s...ETStreetRadial
    I guess for your 17" rim your only choice would be 275/40/17 ET Streets.
    I never used the ET street IIs but my understanding is that they are just the lower profile version of their regular et street radials. Seems like a good bit of people run them though if you look around.
    Are you looking for a tire that dead hooks on the strip or a tire that just puts the power down on the street or what? On a stick car IMO I'd just pick up a set of 16" rims and run a bias ply et street if I was just trying to hook on the track and then swap your street wheels back on to go home. But for a tire that does both clear weather street driving and also grabs at the strip, the ET street IIs probably work fine.
    BUTLER,PA
    161
    Thanks for your help man! I will mainly just be on the street, but I wanted something that hooked pretty well. My 555Rs worked good at 460hp for me, but I heard would be useless at 600hp. The ET II's seem to be similar to the 555R
    Mar 2009
    796
    If hooking is your goal, you want taller sidewalls.
    Low profiles are mainly for rim fitment.
    robinson
    1,091
    Quote Originally Posted by PaceFever79 View Post
    truth
    if you are stick shift i would go bias ply but if you wanna go fast with auto use radial.
    Quote Originally Posted by LS3GTO View Post
    "Sir, do you like getting killed by LSx powered vehicles ?"
    Quote Originally Posted by dannythekid View Post
    You can't swing a dead cat without hitting a car with a LS motor in it (Especially at 1st-Try!).
    /twocents
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    The ET street radial II has the same compound as the ET street radial which I have, its a very soft compound and wont last long at all on the street. I have about 10 track passes and less than 200 street miles and they are down to the wear bars already. Using them on the street will really wear them out quik. I would use the Nitto for the street, unless you like buying tires frequently.
    89 Vert, Stock block, H/C/I , DIY turbo kit MPT70 , Tweecer RT, C4 trans. 17 lbs boost. 3400#s - 10.3 @ 136 mph.
    Dyno Jet - 542 RWHP / 545 RWTQ
    BUTLER,PA
    161
    Ok, so I talked to American Muscle. They misprinted on their website. They do not even make the original ET Street Radials in 315's. So they said they would return them for no charge and was very professional about it. So my question to all of you is: what is the best dry weather drag radial for my 17 X 10.5 inch rims for hooking up on the street. I should be making around 600HP. I am not too worried about how well they wear.
    BUTLER,PA
    161
    How about the NT05R's in 315? or What size would I run if I went with the original ET Street Radials?
    Somerset Co.
    2,907
    I have a set of 315-35-17 Hoosiers that when combined with 6000 rpm grip well enough to do this
    BUTLER,PA
    161
    Wow, not sure I want to hook that well :D anyone know anything about the Nitto NT05R? They look pretty mean
    Going fast with class Slow01GT's Avatar
    Mars, PA
    1,696
    The NT05R's are a good tire, but imo they won't hook better than the et street radials you currently have. I wouldn't worry too much about wear either since I managed to get about 1k street miles and over 100+ track/fld passes with my original et radials.
    Dennis
    2006 GTO
    Gone but not forgotten
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    l3@l)&#l_#$$ AdamantiumSilvr's Avatar
    Dec 2008
    Natrona Heights PA
    3,056
    Here's a grrreat comparison test I found between the NT05R's and the M/T DRII's!!
    http://www.superchevy.com/technical/...est/index.html
    If you look on the second page the Nitto's barely beat out the M/T's! I've been leanin towards gettin the NT05R's but I'll buy the M/T DRII's off of u if you don't want to send them back, cause I've been lookin for a set for my 10 1/2" Bullitts I got! Shoot me a pm if you wanna work something out!?
    Bu-2000-bash
    ALLSQUAD
    Steel City Muscle Cars
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
    Cranberry Twp.
    344
    Quote Originally Posted by Slow01GT View Post
    Thats because you dont have enuff power to spin them
    Mars, PA
    1,696
    Quote Originally Posted by Black Vert View Post
    The majority of those passes were with my Mustang so you are probably right
    Dennis
    2006 GTO
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    BUTLER,PA
    161
    Great info guys! Thanks a lot!
    Quote Originally Posted by AdamantiumSilvr View Post
    Thanks for the article man! I'm gonna do a little more research and I'll let ya know
    never stock biminiLX's Avatar
    Beaver
    2,406
    You have/had the best tires for what you want. The new Nitto NT05R are probably very close to both street hook and unfortunately wear. My brother has been 1.40s 60' on the ET Street II 305/35/18s so they will hook very well. However, with a stick and big low-end like you have, the bias-ply old-school type ET Street will probably work better at the track due to absorbing a clutch dump.
    Dec 2008
    Natrona Heights PA
    3,056
    Noo...
    ...problemO n sounds good ta me!!!
    Quote Originally Posted by 724COBRA View Post
    Bu-2000-bash
    ALLSQUAD
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
    Don't forget about the bfg DR's. Also the M&H. Both are going to hook better than the nittos.
  1. used et street radials
    By Black cobra in forum Ford Vehicles
    Last Post: 05-01-2011, 05:06 PM
  2. WTB 15" drag radials, or et streets
    By Cam99 in forum Ford Parts
    Last Post: 05-04-2010, 08:46 AM
  3. 275/40/17 M/t Et Street Radials
    By ttk53 in forum Ford Vehicles
    Last Post: 04-19-2010, 08:48 AM
  4. MT ET Street Radials 255/50/16
    By ModularMike in forum Ford Vehicles
    Last Post: 10-12-2009, 04:18 PM
  5. OEM 03 Cobra Chrome Wheels, MT ET Streets, MT Drag Radials
    By Blackcobraconv in forum Ford Vehicles
    Last Post: 05-14-2008, 04:05 PM
