Results 1 to 11 of 11
Thread: 03 cobra fuel pressure sensor bad?
    map22 map22's Avatar
    Oct 2008
    monongahela
    458
    Exclamation 03 cobra fuel pressure sensor bad?
    So I'm drivin along today to the car wash and hammered on it once and hit rev limiter spinning and thru a code, p0190, fuel pressure sensor malfunction, I've heard these sensors tend to go bad on modded cars any ideas before I go spend cash on this sensor??
    2003 Sonic Blue Cobra
    -Under the knife this winter
    3,356
    Fuel Rail Pressure Sensor is common. I used to carry one as a spare in the glove box.
    Mark
    LeMans Blue Z06
    Fuwkawee
    5,151
    Quote Originally Posted by map22 View Post
    Yeah it used to happen to me every now and again. I just took it to a local garage and have them clear the code.
    17 Ram 1500 Big Horn Hemi
    16 Comp O GT Performance Pack
    Oct 2008
    monongahela
    458
    If I replace that sensor would the check engine light go off or will I have to clear it, I already tried to clear it with my code reader but it wont
    3,356
    Did you replace the bad part first before clearing the code? If so I can clear the code for you once it's fixed. If you are near the Airport area I would be glad to help. Let me know.
    -Mark
    Mark
    LeMans Blue Z06
    Oct 2008
    monongahela
    458
    Well I tried clearing it, it went away for a second then immediatly came back, I got a sensor today I'm gonna put it on tma and then run the code reader through again see if it clears...if that sensors bad is that why I m not able to just clear it like kevin said?
    3,356
    Yes if the sensor is bad it will not allow the code to be cleared. Some sensors are not 'tested' by the engine computer every time you start the car so the code can be cleared even with the bad part still installed, while others will not let you clear until the bad part is replaced. Keep us posted.
    Mark
    LeMans Blue Z06
    Fuwkawee
    5,151
    It only through that code on me twice in the 3 years I had the car. Only hit the rev limiter once.
    3,356
    It seems that if the sensor is actually bad that the code cannot be cleared. That is probably why you were able to clear the code and keep on truckin Kevin. :)
    Mark
    LeMans Blue Z06
    Oct 2008
    monongahela
    458
    Well got the sensor in and then the code cleared, $120 dollars later now I'm good to go
    3,356
    Good to hear!
    Mark
    LeMans Blue Z06
  1. question on fuel pressure
    By vitaleffects626 in forum General Tech
    Last Post: 05-05-2011, 10:04 PM
  2. Good or Bad? How to test your WB o2 Sensor
    By billyNOTnice in forum General Tech
    Last Post: 04-01-2009, 10:45 AM
  3. stock fuel pressure
    By JETHRO in forum Fox-SN95
    Last Post: 03-14-2008, 06:29 PM
  4. Fuel Pressure
    By coralcoupe1993 in forum General Tech
    Last Post: 09-30-2007, 06:46 PM
  5. What is the proper fuel pressure
    By Cam99 in forum General Tech
    Last Post: 03-01-2007, 05:53 PM
