Results 1 to 12 of 12
Thread: Eaton Truetrac Differential
    I have a used Eaton Truetrac diferantial. I bought it used to put into my GT500, but have decided to go another direction.
    The differential has 500 miles on it and works perfectly.
    This should fit any 8.8 with 31 spline axles.
    $300
    Mar 2009
    796
    how are these with high speed cornering?
    Jan 2008
    Jefferson
    4,674
    x2 how is it on the street?
    It is perfectly smooth on the street. It is no less smooth and quiet than stock. Not positive about high speed cornering, but I would think it should be great. It only engages when traction is lost.
    Twin Turbo Saleen 98saleen's Avatar
    179
    Bump
    I run this in my TTSaleen and it is perfect.
    Quiet on the street and pulls both tires equally.
    No slip, no problem!
    Highly recommend!
    Ryan
    Jan 2008
    Jefferson
    4,674
    where are you located?
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    Are there pieces broke off the top edge in the first pic?
    Im located in Whitehall.
    There is nothing broken, that is the way that the edge is from the factory.
    Jan 2008
    Jefferson
    4,674
    How much better is this diff compared to a 03 cobra ford racing one? That is what I was thinking of getting but not 100%. What are the ups and downs of the Eaton and ford racing?
    Well one benefit of the Truetrac is that there are no clutches to wear out.
    To my knowlege, this unit would be much stronger than the ford racing.
    [QUOTE=97LaserRed;256386]How much better is this diff compared to a 03 cobra ford racing one? [QUOTE]
    Talk to Ed (Ares) ... he runs the truTrac and would be a good reference ... FWIW, that is likely what I would of used in my car if I didn't get the Detroit Locker I have now.
    Jan 2008
    Jefferson
    4,674
    I would love to buy this but my impact gun just broke at work today. So if I can fix it, I will buy this diff. If I have to buy a new IR impact gun, Ill have to wait :( I'd love to come get it soon. If you dont sell it I WILL buy it once I got the cash!!
  1. 94 Ranger Differential ?
    By pRojekt02GT in forum Other Ford
    Last Post: 06-04-2012, 07:44 AM
  2. Wtb 7.5 traction lock differential.
    By SK@StreetLethal in forum Ford Parts
    Last Post: 09-27-2010, 08:56 PM
  3. WTB differential, axles, gears
    By White5.0 in forum Ford Parts
    Last Post: 05-29-2010, 10:34 PM
  4. 99-04 IRS Differential Oil Cooler Kit - $300
    Last Post: 02-23-2010, 09:40 PM
  5. Replies: 6
    Last Post: 06-16-2007, 05:53 AM
