Results 1 to 3 of 3
Thread: Motorworks auction May 8
    For those who may not know, Mark Brewer, Ford man extrordanaire and the man behind Motorworks, passed away in November. Christine, Mark's wife, had to make the difficult decision to close the shop. There will be an auction on May 8 9am for all the equipment and parts. I hope the link works.
    http://www.auctionzip.com/cgi-bin/au...670&category=0
    If not, here is the description:
    Garage Equipment Auction Former MotorWorks
    May 8th at 9:00 AM.Preview 8:00 AM.
    2 Forward car lifts 9,000 lbs recently serviced , Emissions machine OBD2 complete with computer for 1996 and newer models, Time clock w/ cards, snap on smoke tester, Snap on Air condition machine recovers and charges, Sun emissions machine with tail pipe snifter One of the last working also has gas cap tester Complete unit recently serviced, Flow bench, Snap on trouble light, Pump and Drain bucket for oil changing, Drill doctor, whirlpool water cooler, ingersol rand air compressor 60 gal, Large snap on big red air compressor,
    1 scissor lift eagle equipment. Numerous shelving units. Skat Blast bead cleaner, Belt Sander and Grinder Polisher, Large Drill Press, 1 adjustable table Drill Press, One Large Parts Cleaner Tank Magnus, 1 smaller parts cleaner tank, 1 large oil tank with 1/8 tank of oil 5-w30 (holds 150 gal) with crank, Gas Caddy w/ extra seal 25 gal, Headlight aimer, 3 large wooden work benches, One metal work bench med size, 2 large vises, and one small vise, Snap on Tire Changing machine, Snap on Tire Balancing machine w/ extra weights and soap, 2 oil catch cans, Cherry picker engine lift, numerous air hoses, 2 step metal steps, 1 full 55 gal drum 5w20 oil, one full 55 gal drum antifreeze, Cranks for 55 gal drums, 1drum valvoline lube gear oil, 1 drum valvoline chassis lube, Assorted muffler clamps complete in cabinet, assorted headlights in cabinet, Air conditioning parts, Different wall cabinets, Snap on Break Lathe, Carbon Clean motor Vac (needs pump), Branick spring compressor, Thermostats in Napa cabinet, Pipe bender for making exhausts, Catalytic converters, mufflers, and pipe for exhausts, fuel line repair kit, 4 heavy duty jack stands, Heavy duty Jack, smaller hydraulic car jack, Assorted torches with tanks and cart, Wagner lighting with cabinet, Large 16 gal craftsman shop vac, Assorted office furniture desks, chairs ect,
    Assorted Advertising clocks, Exhaust hoses, Battery cables, Chains, numerous drawers full of vac caps rubber rings, drain plugs, tube nut assortments, fuses, gaskets, grommets and too much to mention, also radio receiver, credit card machine, lots of oils/ tranny fluids/ break pads/ spark plugs/
    Fluids/ bolts, brake lines/ fuel lines/ fuel filters/ hose clamps on rack/ pcv valves/ wiper blades/ lots of inventory items needed for car repair some hard to find. Small metal storage drawers, Johnson first aid kit. Lots of shop manuals, And more items
    We are still gathering. Most machinery still has original manuals.
    ChuckT
    Sponsored by
    Wholesale Transmission - New Kensington
    Millerstown Pic A Part
    Your mom cwh19's Avatar
    May 2009
    Greensburg
    1,383
    Im assuming its at the shop?
    The best former Rodeheaver's Hot Rod employee ever.
    15gt
    Premium - Performance Pack - Recaros
    94gt
    410w - faceplated t56 - s478 - Gone
    Yes, 1020 Broad St, Greensburg.
    ChuckT
    Sponsored by
  1. Barrett-Jackson Auction
    By blackfive-o in forum The Bar
    Last Post: 01-21-2012, 09:28 PM
  2. Daytona Coupe up at Auction!
    By map351 in forum The Bar
    Last Post: 02-26-2009, 08:09 AM
  3. Auto Auction
    By Mitternacht in forum The Bar
    Last Post: 10-02-2007, 02:21 PM
  4. mustang auction
    By INSANELY CRAZY in forum The Bar
    Last Post: 03-27-2007, 11:17 PM
  5. Did anyone happed to see this auction?
    By Sonic03snake in forum The Bar
    Last Post: 01-06-2007, 01:52 PM
