Results 1 to 20 of 35
Thread: Frustrated!!
    Senior Member 89 vert's Avatar
    plum
    487
    Frustrated!!
    Well, last week I was leaving a car show, the motor started banging, almost like an aluminum bat was banging on the valve cover. I towed it home. I removed the top, thinking I floated a lifter or bent a push rod maybe. I found a slightly bent push rod, so i replaced all of them including all new lifters. I changed the oil as well and as I loosened the drain, a half cup of anti freeze came out!! So I filled it up and decided to crank it up. It was banging just as bad as it did before. So after 3 long nights of hell, it went on the trailer and went to Rodehavers tonite. I'm praying its not as bad as I'm thinking. Good luck Tim!
    MSD ignition/King Cobra clutch/Polished Cobra upper and lower/Ported GT40p w RR/ 70mm tb/ 24 lb injectors/ pullies/ Mac cold air/ Mac long tubes/ H pipe/ 3:73 gears/ 3g alt/ welded sub frames/ Alum driveshaft/ CC plates/125 shot of juice/custom trunk/suspension goodies.
    FIRST PLACE 87-93 FOX BODY BUCKEYE STANGS SHOW 2010 AT SUMMIT RACING
    283 hp / 320 tq on mustang dyno (all motor)
    Mt Pleasant
    2,916
    sucks...good luck
    2,247
    sounds pretty scary to me. good luck man
    Black
    It's a Bird!! 1Badbird's Avatar
    Jan 2009
    Masontown, Pa.
    1,618
    Good luck! Hope it's not that bad.
    ----Jay----1988 Thunderbird 5.0 AOD
    Big Daddy gmkillr's Avatar
    At the racetrack
    4,193
    Did you set-up your rockers & valvetrain?
    WHat is the process you followed?
    Corvette Z06
    2,145
    Sorry but its engine rebuild time because I can only think of one way for a push rod to get bent. Yep the piston and valve tired to share the same space at the same time. Now this can be cause a few different ways but the out come is never good.
    Stock 03 Cobra Vroom Vroom!!
    Quote Originally Posted by RUTHLESS View Post
    While it doesent account for the coolant in the oil, there are LOTS of ways for a pushrod to get bent. I've seen more bent based on geometry than anything else. The noise doesnt help either ;)
    2,145
    True true. I guess we would need to know how bent the push rods were before jumping to conclusions. (visual or rolled on a piece of glass) I have heard of new engines eat push rods because they were not the correct length because the heads were milled down so far or older engines that were mechanicly over reved the engine. Shifting for 3rd and going back to 1st. OUCH
    plum
    487
    Well, Tim called today,(the 4th of July) and he was working on it this morning. It fired right up for him with no banging! He thinks the lifters were not pumped up all the way with oil. He will be doing a compression test monday, cause he thimks the head gasket could be bad. As far as the push rods go, I did the mirror test and 2 of them wobbled. I did over rev the car a few times due to the damn floor mat gettin wedged in the gas pedal(they are now in the garbage) so well see what happens this week.
    Was up there at his shop this morning. I didn't hear anything that sounded bad when he was moving it. If its any consoling, the car looks great!
    I hope everything turns out ok. I'm just glad to see that you still have the car!!!! Keep us posted.
    It isnt like the 4 cylinders. When you pull the intake, coolant gets in the oil. A good bit of it too. There are ways to minimize it but you always get some. Jacking the rear of the car up can cut down on the ammount.
    plum
    487
    Thanks guys for your input. When I took off the rear heater hoses, anti freeze leaked straight into the head, maybe a half cup or so. Im glad it sounded good this morning at Tims, the banging was so loud all I could do was think the worst, so off it went to Tims.
    plum
    487
    Talked to Tim today and he found the head gasket on the drivers side is bad. Could have been worse.
    plum
    487
    Well, just a little update. Tim got the drivers head off and of course the piston was busted and it tore up the cylinder wall. I found a stock 88 motor that I am picking up this Saturday. Wish I could do a stroker but money is tight, so this will hopefully work. My car had junk cast pistons.
    Mt Pleasant
    2,916
    glad to hear you figured it out. tim will have her fixed up in a jiffy
    sorry to hear about the motor but glad to see you got it figured out so quickly
    BIG BLOCKS WITH TURBO'S turbo'dnotch's Avatar
    Apr 2009
    Myrtle Beach,SC.
    197
    :)I have a 347 stroker shortblock fresh from the shop, with an ATI dampner and flywheel for 2200.00. Just an idea:)
    Speed Kills....Play it safe and buy a CHEVY!!
    my ride has 1400 hp! blaze00's Avatar
    Apr 2009
    weirton
    485
    Quote Originally Posted by turbo'dnotch View Post
    yeah get this
    2011 gt
    2013 wrx sti
    2011 yz450 dirt scooter
    2012 yfz450 wuad
    Apr 2009
    Myrtle Beach,SC.
    197
    Its a stock block,steel crank,forged rods and KB pistons with a single moly ring. All machine work and assembly done by Canton automotvie machine service, A guy named Roger Decker. In fact the engine is so fresh, I have not picked it up yet,lol.
  1. So frustrated with electrical gremlins
    By Jivepepper in forum SN95-New Edge
    Last Post: 11-30-2008, 11:57 PM
