Results 1 to 2 of 2
Thread: lincoln Mark VII rear for 87 Mustang brake conversion?
    Cheap SOB
    Baltimore, Maryland 21236
    288
    I need some advice. While out trolling for parts I came across a guy working on a project Falcon. He had an 8.8 rear for the car but later got a 9 inch. He was wondering if I would like the rear for 75.00 dollars.
    The rear is out of (he thinks) a Lincoln Mark VII – 1991. It is a complete rear, all hoses, calipers, rotors, axles and gears. The rear is not a TracLoc unit, but an open rear with 307 (?) gears. So I know I will want to replace the differential and gears seat. What intrigues me is whether I can use this rear as is for a drum to disc brake conversion. All the brakes parts are there. If the axle is not too wide and the control arms mounts line up, this should work, right?
    I already have a GT master cylinder and booster in the shed. I would need an adjustable proportioning valve. Anyone know where I can get the plug used to gut and cap the stock proportioning valve?
    THANKS.
    Sexy and i know it fast4ord's Avatar
    Gibsonia
    772
    They are wider for sure, here is some info
    http://www.coolcats.net/tech/advanced/4to5lug.html
    My collection:
    01 cobra in pieces
    02 dodge cummins
  1. Lincoln Mark Vii LSC interchange
    By coralcoupe1993 in forum Fox-SN95
    Last Post: 10-14-2014, 09:14 AM
  2. 1990 Lincoln Mark VII LSC
    By mustang50lx in forum Ford Vehicles
    Last Post: 06-27-2014, 10:33 PM
  3. Replies: 27
    Last Post: 11-03-2011, 11:31 PM
  4. WTB: Lincoln Mk VII rear brake parts
    By 50Dro in forum Ford Parts
    Last Post: 07-26-2010, 08:07 AM
  5. 1991 Lincoln Mark VII
    By dpstang98gt in forum Ford Vehicles
    Last Post: 07-15-2010, 10:41 PM
