Results 1 to 20 of 20
Thread: Thermostat?
    Walking on the wild side! Shadowstealth's Avatar
    Jul 2008
    south park
    624
    Thermostat?
    Yesterday on my way home from the hospic I was put putting back home and when i was in third gear i noticed that my car sputered for a sec. and i looked down and i noticed that my temp gauge wasnt in the middle anymore and was moven rapidly to the hot side. i was able to get off the road and i opened the hood and couldnt find any antifreeze leaking... and my heater wasnt really blowing hot. i got a few bottles of water in it... but when i put the first one in.. i heard a click on the pass side of the motor.(perhaps where the thermostat is located) and it almost like burped the water.. the temp went back to normal after that then.... just bc of miss belief i turned the car off with the blower running and then started it back up and the temp gauge went back threw the roof.... i was able to get it home but... it took some time... anyone have any flippn idea on what just was going on with my termi?? im clueless.. if its a thermostat or a check valve? something that automaticly opens to allow fluid threw? i dunno
    2003 Cobra w/ very mild mods, Magnaflow catback and cold air intake
    1992 Mustang lx hatch back, cold air intake, underdrive pulleys, offroad h pipe, mac muffs with dumps.
    1988 Toyota pickup w/ 4inch suspension lift on BFG 33's Stainless steel header and full exhaust
    2005 Honda Trx 450R w/ protaper bars and grips, nerf bars and under body armor. ~for sale~
    Slow Vehicles Team SonofaBish's Avatar
    Spencerport, NY
    3,762
    well if it "burped" like you said, have you bled the system to make sure the there isn't any air in it... my LT1 had bleeder valves on it... my LS1 had a self-bleeding system... not sure what the cobras would have
    2015 Corvette Z06
    - Shark Grey / Kalahari
    - bolt-ons, tune, lots of carbon fiber (642/671 rwhp/tq)
    Senior Member RUTHLESS's Avatar
    2,145
    Man these cars are a bitch to burp correctly and seem to hold air bubbles that kick loose months down the road. When you added coolant did you add to the fill port beside the blower or did you open the coolant res tank?
    The thermostats on these cars are located on the front drivers side down bellow the res tank. Its a aluminum housing that a few hoses run to. Its is not bolted to anything it is just suspened by the hoses.
    When I first saw your post I thought it was going to be about a leaking res cap like some many of us seem to be having lately.
    Stock 03 Cobra Vroom Vroom!!
    Proudly supports Street Lethal Performance and Rodeheaver's Hotrod Shop
    If you car overheated you are loosing coolant.
    You need to find out where.
    I recently had a weird problem that ended up being the expansion tank leaking at the seam, but wouldn't leak at idle....only while driving. It was a pain to figure out where it was leaking from, short of getting a system pressure test.
    Jul 2008
    south park
    624
    well the heres another thing i didnt put on here... when i turned on the heater.. i had warm air pretty much blowing what was outside in. now when i turned the car off and started it up again. the heater was blowing hot. and the temp gauge was above normal.... but when i changed the settings i then blew warm again not hot.... and i could smell anitfreeze? does that make any sense?
    Jul 2008
    south park
    624
    Quote Originally Posted by RUTHLESS View Post
    last night was the first time ive had this problem... and it was like all of a sudden... my brother thought there could be a relay or something... but where i got the diagram from the dealership and theres no electronics to the thermostat.
    Quote Originally Posted by Shadowstealth View Post
    I am no mechanic, but smelling anti freeze with the heater on probably isn't too good of a sign.
    Matt
    94 Ford Ranger
    01 KX125
    2002 Ford Mustang GT - 13.96 @ 98.8 (sold)
    Boat's and Hoe's fordandmopar21's Avatar
    Aug 2008
    226
    everytime somebody told me they could smell antifreeze it ended up being they had a bad heater core. is your passenger floor wet? you could be loosing antifreeze through a bad heater core.
    Justin
    Spencerport, NY
    3,762
    Quote Originally Posted by fordandmopar21 View Post
    x2!
    2015 Corvette Z06
    Jul 2008
    south park
    624
    o lord! that was one of my thoughts but no i havent checked the floor yet.
    Jul 2008
    south park
    624
    but what is another tall tail sign? how much do you think thats going to be?
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    usually the floor won't get wet. the heater box should have a drain that leads outside, otherwise your floor would get wet when the ac is on. Also, even if the thermostat wasn't opening, you should still get hot air from the heater when the car is fully warmed up. I know the older Fords had a bypass for the heater, so I'm assuming the newer ones do too. Serves two purposes, relieves pressure from behind the thermostat, and allows windows to get defrosted BEFORE the thermostat opens. Otherwwise you would have to wait until your car reaches like 190 degrees before you could drive it...lol.
    2014 Mustang GT m6 - 12.97@111
    All stock down to the tires
    12.53 on slicks. Stock. No tune.
    1986 Mustang 5 speed - 12.10@110 off the sauce
    11.05 on Nitrous babying a hurt t-5
    327 stroker BOSS block with junk Pro Comp heads
    355hp n/a
    520hp on nitrous
    All Nitrous parts are gone. Turbo on the way
    Tuned by Tim @ Rodeheavers Hotrod & Dyno Shop
    Uniontown, PA
    533
    you could get your system pressure checked. If it doesn't hold pressure, you got a leak somewhere. If it does hold pressure, then I'd say your heater core is not the culprit.
    355hp n/a
    520hp on nitrous
    Jul 2008
    south park
    624
    thanks juice! ill see if my brother can check it out for me while im at work tommarow!
    2,145
    Any luck with your issues?
    Jul 2008
    south park
    624
    YESSS! lol i think so.... buddy ill tell you what... the problem im taken is fixed but i am so worried that the cooling problem may come up again. my brothers a good mechanic and i put it in his hands... well, he sucked the system and filled it back up but the problem came back last sat. night. well monday he did the same thing and sucked it and filled the cross over tube... then he took it out for 40 min and he said he put prob. 20 miles or more on it. so i dunno... i wont be driven it long distances any more bc im worried... "*****cat" haha.... we shall see..
    2,145
    Just do what I did...If she give you problems just tell her to shutup and like it. Then give it to her harder.
    Yep this works for both car and women. j/k
    I babied the hell out of my car after putting the KB on but now its game on. I figured if I drop money into it I should have fun. If she blows she blows! There is nothing I can do about it. Think of it this way...I bet the last time you had an issue you were just driving slow and not bothering anyone. Am I right? So next time around you should be WOT and laughing your ass off. Its money better spent that way. Enjoy it!
    pa
    860
    PIIHB! That works too! (not for me:( )
    Jul 2008
    south park
    624
    All my cars have had some kinda issue like that... my toyota pickup has been jumped , 4wheeled , towed a 88 suburban out of a pond and i drove threw the pond afterwords up to the bumper in muck... lol but these american cars.... need some tlc all the time haha.
    FAST WIT A FORD OVAL 90TitaniumStang's Avatar
    Feb 2009
    Latrobe
    517
    if you need the pressure tester dont buy one i have one if ya need to borrow it just ask
    1989 GT Black,full 16 pt MOLY 8.50 CERT.
    461w Dart block w/ 4 bolt-all 5 caps
    EAGLE PENDULUM CUT ESP ARMORED 4.250
    PROBE PISTONS
    PROBE BILLET I BEAM
    super victor
    230cc CNC
    Hooker 2 in headers
    pa sc c4, 4600 stall
    9" LADDER 3.70 PRO GEARS
    SW BACKHALF
    moser 35 SPLINE axles
    1050 RACE DOMINATOR DEMON
    250 FOGGER KIT
    snow performance stage 2
    1.316 60ft 9.16@156
  1. Thermostat question..
    By Hawkeye in forum Fox-SN95
    Last Post: 09-26-2009, 02:32 PM
  2. WTB Fox thermostat housing
    By Silverhatch in forum Ford Parts
    Last Post: 09-23-2008, 08:49 PM
  3. Thermostat
    By Black87GT in forum General Tech
    Last Post: 05-12-2008, 09:10 PM
  4. SVO/Turbo 4 thermostat housing bolts
    By mlowry1260 in forum Fox-SN95
    Last Post: 08-05-2007, 11:11 PM
  5. wtb thermostat housing
    By scott5 in forum Ford Parts
    Last Post: 04-28-2007, 09:13 PM
