Results 1 to 17 of 17
Thread: Complete 5 speed swap
Hybrid View
    1,220
    I have a complete 5 speed swap for a Fox body with many new parts. You will get a used T-5, a Quick time non SFI steel bell housing and block plate, A Ram Powergrip clutch, A Ram flywheel, A Steeda Tri-Ax shifter, Steeda Clutch quadrant, Steeda clutch cable, Steeda firewall adjuster, Clutch and brake pedals, steel driveshaft, and the wiring jumper for the 5 speed stuff. The Bellhousing, clutch, flywhhel, and most of the Steeda stuff has around 20 passes on it and about 200 street miles. It is all still in the car. You can drive it before I remove it. The only thing you will need to buy seperate is a pilot bearing. $1500.00 724-516-1605
    Jan 2008
    Jefferson
    4,674
    do you have just the clutch dust cover? would you sell just that?
    State College, PA
    3,552
    do you have the harness that goes between the 2 prong sensor and the car's wiring harness? i think thats the one i need....if so, would ya sell it separate?
    2013 Mustang GT
    1999 Contour SVT
    Have that also, 10 bucks
    JUNK IT!
    1,220
    That has to stay with the setup. Sorry. I am sure you saw that How Much? has one for you.
    1,220
    I may split this up also. Make offers on what you need.
    1,220
    I don't think I have that part. I will have to check. You don't use it with the Quick time bell housing.
    I have that, 10 bucks
    JUNK IT!
    Sorry, didnt me to Highjack ur Thread!! Bump On good Deal
    JUNK IT!
    Greensburg
    843
    I am interested in the block plate, clutch cable, firewall adjuster, and maybe the clutch?
    -Frank-
    1986 GT-- HCI
    2011 WRX
    1999 B2500 7.5/9 drop
    1,220
    Quote Originally Posted by turbo83coupe View Post
    The block plate goes with the bell housing. The rest will be for sale. I am going to want $50.00 for the cable, firewall adjuster, and Quadrant. (I bought them all as a set.) I want $150.00 for the clutch, pressure plate, and throw out bearing. (Cost $350.00 at Summit.)
    The Bell housing and one of the transmissions have to be sold before I am taking the car apart. I don't want to sell small stuff and end up with a non running car I can't afford to fix.
    Boat's and Hoe's fordandmopar21's Avatar
    Aug 2008
    226
    Would you sell the steeda tri ax? If so ill take it.
    Justin
    1,220
    Quote Originally Posted by fordandmopar21 View Post
    I will sell the Tri Ax after I sell the Trans and bell housing. $100.00
    1,220
    This setup will have miles and 1/4 mile passes added to the total until the stuff sells. I'd rather be racing with an automatic, but I'll race with the stick until I can afford it. It's not as consistant as an auto, but a bad day at the track beats a good day of yardwork every time. (Unless the bad day involves broken sh*t or a crash.):)
    Oct 2007
    creighton pa
    260
    broken sh*t, not you.
    2014 301a GT a6
    5c circle d conv, 3.31's, kooks l/t's & orh, stock intake, bmr susp
    1,220
    Bump Lower price. I am going to keep the pedals. Make offers on parts if you want. The worst I can do is say no. I want to sell this stuff to get my C4.
    I have a 5 speed parts for a Fox body with many new parts. You will get a used T-5, a Quick time non SFI steel bell housing and block plate, A Ram Powergrip clutch, A Ram flywheel, A Steeda Tri-Ax shifter, Steeda Clutch quadrant, Steeda clutch cable, and Steeda firewall adjuster. It is all still in the car. You can drive it before I remove it. $1200.00 / offer for all or I will part it. 724-516-1605
  1. Replies: 12
    Last Post: 11-28-2014, 09:29 PM
  2. 99% complete eaton swap
    By jaa55 in forum Ford Vehicles
    Last Post: 01-27-2014, 08:37 PM
  3. WTB: Complete pi swap.
    By AutomagicSN98 in forum Ford Parts
    Last Post: 08-15-2012, 06:36 AM
  4. For sale complete tremec swap
    By 89gt308 in forum Ford Vehicles
    Last Post: 09-03-2008, 08:52 PM
  5. complete t5-AOD swap
    Last Post: 12-02-2007, 11:44 AM
