Results 1 to 5 of 5
Thread: piston to valve clearance
    stuntman blksunshine88's Avatar
    Aug 2008
    duquesne
    544
    i have a 94 gt with GT40 p heads 1.6 rockers and a tfs stage 2 cam project in the works, anyone ever run this combo? i assembled one head with check springs in it and i have .164 on exhaust and .135 on the intake but this is with hyd roller lifters in place, i hear you should use a solid one to check but i can't compress the lifter at all so am i ok??????
    -greco
    92 Coupe, 10.72@133
    if you have the checker springs on the valves, they will not depress the hyd. lifters, and .100 is the least i ever go..
    Aug 2008
    duquesne
    544
    thanks tim i can't wait to see how this thing runs with the new combo i'll post some pics up of the porting that torqueboxer and i did on my P heads
    -greco
    92 Coupe, 10.72@133
    Member torqueboxer's Avatar
    white oak, pa
    638
    UPDATE>>>>>>it runs good!! Plenty of valve clearance
    Aug 2008
    duquesne
    544
    yes it does
    -greco
    92 Coupe, 10.72@133
  1. Sears Powder Coat Gun - Clearance
    By daviac5000 in forum The Bar
    Last Post: 04-01-2009, 10:05 PM
  2. Clearance sale @ HO Fibertrends
    By Sonic03snake in forum The Bar
    Last Post: 10-01-2008, 12:28 PM
  3. valve and Piston-not a good relationship
    By LXguy88 in forum Fox-SN95
    Last Post: 09-29-2007, 06:16 PM
  4. fundamentals of piston to valve clearance
    By George C in forum General Tech
    Last Post: 11-11-2006, 01:28 PM
