Results 1 to 5 of 5
Thread: SN95 - Speedo works, odometer stuck?
    Cheap SOB
    Baltimore, Maryland 21236
    288
    I was using the trip odometer to measure how many miles I had on this rebuilt motor. Things were going well. I had the dash out to fix the headlight switch and I had it out again to replace the dash light bulbs.
    Somewhere during this last week the odometer and trip odometer have stop working. I have had 60 miles on this motor for the past 120 miles. The Odometer was rolling over from 120099 to 120100 when it seems to have gotten stuck. The speedometer is still working. Since this is a 95 Mustang, I believe this is all electronic.
    So how did I break it? More importantly, how do I fix it?
    Cheap SOB
    288
    i was also going to suggest that you check to mke sure that the odometer is still plugged in on the back of the cluster. On the 94-95's if the odometer becomes unplugged for some reason everything except the odometer will function. :)
    Cheap SOB
    288
    I only remember two ribbon cables. Maybe I should go looking for that speedo cable.
    Thanks.
    Cheap SOB
    288
    Got it. You meant the small cable and connector that powers the odometer drive motor. The motor is plugged in. But I am missing teeth from the driven gear. I am guessing that the gear was able to hold up to rolling two digits, but when it came time to roll three digits at a time, a few of the gear teeth broke off.
    DRRummel
  1. odometer trick
    By map22 in forum General Tech
    Last Post: 02-06-2011, 02:12 AM
  2. Odometer and speedometer not working
    Last Post: 04-01-2010, 11:46 AM
  3. Odometer Cluster
    Last Post: 12-05-2009, 05:00 PM
  4. 3 pillar gauge pod + Odometer cluster trim
    Last Post: 12-20-2007, 06:08 AM
  5. Accellerator stuck
    By 03 OW SVT in forum The Bar
    Last Post: 03-21-2007, 06:07 PM
