Results 1 to 20 of 30
Thread: some transmission troubles....
    Senior Member White5.0's Avatar
    State College, PA
    3,552
    Im having a little problem with my tranny grinding while putting it in second gear. its a t-5 by the way
    heres the catch though: it only does this going uphill while shifting into second.
    EVERY other time i put it in second on a level surface or downhill, if i am upshifting, downshifting watever, it does NOT grind, and shifts nice and smooth. i havent tried putting it into other gears going uphill tho, only second. I've only driven it for probably a total of 1/2 mile since i got it running because of bad weather and not having it inspected or registered yet.
    i am using (i think, hard to remember) penzoil ATF and i think its non-synthetic. and when i filled it up, i took the top plug out and filled through the shifter hole till it started pouring out of the top plug then plugged it back up. i dont see it leaking anywhere so i dont think its losing tranny fluid.
    do i have enough fluid? should i switch to a better fluid? what is the deal here?
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    You need synchros.
    State College, PA
    3,552
    Quote Originally Posted by wick View Post
    You need synchros.
    wouldnt it do it on any surface then? uphill, downhill, level, etc??
    its just happening when going uphill (well, so far......i havent driven it much, just around the block a few times)
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Different loads. Nope. Sometimes its smoothe on the flat.Easy shifting. Up hill there is more load and you scrub more speed between shifts. The fiber synchro material is worn down to almost nothing.
    State College, PA
    3,552
    well if that is the case then i am a bit pissed off because a member on here sold me the tranny who said it was flawless and had no grinding or any other problems what-so-ever.
    how expensive is it to fix a problem like this?
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Nothing clever to say.... jaa55's Avatar
    Sep 2007
    Dayton PA
    3,795
    i dont know how much the synchros cost but the tear down and rebuild you can probably do yourself.
    when i had my CJ-7 i ripped 3rd out of my t-5 and my dad had it fixed in under a couple hours
    03 Torch Red Anni. Ed. Cobra
    11 Grabber Blue 5.0, 3D500 spoiler, CS valance, GT premium, interior upgrade package, Brembos, MT-82 and Whipple powered SOLD
    01 cobra: traded
    93 LX Modular 4v swap
    Sean Hyland Motorsport forged rotating assembly, Teksid block, 01 cobra heads, cams and intake SOLD
    State College, PA
    3,552
    Quote Originally Posted by jaa55 View Post
    yeah i dunno ive never done it before...maybe ill buy a junk one and rebuild it and learn on that one rather than taking the only one i have out of the car and having my car sit again .....maybe i can live with it for a while because for now i think its only second.
    it just pisses me off tho because of what i was told about the tranny before i bought it. i pm'ed the person i bought it off of to see what he has to say about it. so we will see what happens.
    will a better fluid maybe reduce this grind a little more? maybe switching to synthetic?
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Quote Originally Posted by White5.0 View Post
    Syncros work on friction. It's grinding because the fiber is off the syncro and can't work as intended. Adding a "more slippery" fluid will make it worse.
    Talk with Rob (Wick) about fixing it ;)
    State College, PA
    3,552
    Quote Originally Posted by Martin0660 View Post
    ahh i see...Thanks for that info i have been speaking to wick about it also.
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Senior Member SUPERDUTY's Avatar
    Jan 2008
    181
    hey keep me posted on this Noone better have rupped you off I hope this guy will make it right
    2007 Hummer H2
    2006 Hummer H1 ALPHA
    Ford guy turned GM
    State College, PA
    3,552
    ive been discussing this with some people and was told that maybe the clutch needs adjusted? i have stock cable and quadrant right now. i thought in order to adjust the stock one you had to put your foot under the clutch pedal and push up. i tried this, and it did not work and didnt do anything.
    would maybe buying an adjustable cable and quadrant help fix this problem? i personally do not think it will since it shifts fine most of the time except for going uphill, but this is what ive been told to try. what do you guys think?
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Where does the clutch start to engage? Right off the floor? If so, possibly yes. That will fix your problem. If its high, then no.
    State College, PA
    3,552
    i remember it seeming low but i dont remember it grabbing right off the floor. i barley drove it though....ill have to take it out again either this weekend or next since im up at school now and pay more attention to things like that.... i will keep this thread updated
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    02mineralGT Johnny B's Avatar
    Nov 2007
    Elizabeth
    181
    while you guys are on this topic 2nd in my 02 gt is shot. it progressively got worse over this past year and im guessing its my synchros? i cant even downshift into second it pops right back out and even sometimes during hard shifts it pops out as well. any input and about how much am i lookin to get it fixed?
    l3@l)&#l_#$$ AdamantiumSilvr's Avatar
    Dec 2008
    Natrona Heights PA
    3,056
    Mine two grinds every once in a while goin into second. Maybe a half a dozon to a dozen er so times since i've been drivin the car from 00' to present. Now I got the Short Throw in it, I've done it two or three times, once real bad! I just thought my clutch wasn't engaged quick enough and I wasn't used to the ST yet.
    So I make sure I push the clutch the whole way to the floor before pullin it back. I was wanderin if it was my syncros too.
    Yeah, how much does this cost to get fix? Will u ruin your tranny if u keep runnin it like this?
    It never was like this all the time just, as soon as I forget about it or drive the car for a while it will just happen outta no where. And then, I'm like F***!!
    Bu-2000-bash
    ALLSQUAD
    Steel City Muscle Cars
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
    Just spank it!!! Viper_ed's Avatar
    Fayette City, PA
    5,841
    Ryan, I can tell you that the person you bought it from is as stand up as they come. There's NO WAY he would ever try to rip anyone off.
    The suggestions that the clutch may be out of adjustment is very possible. I had a similar issue with my 03 Cobra when I changed the clutch in it.
    Sep 2007
    Dayton PA
    3,795
    have someone get up under the car and pull back on the clutch fork and pick up on the pedal at the same time
    01 cobra: traded
    State College, PA
    3,552
    Quote Originally Posted by Viper_ed View Post
    yes Ed he is a good person...i have been pm'ing him and he is willing to help me out so its all good.
    what was the type of adjustable cable you told me i should get that one time? or maybe it was a firewall adjuster? cause ill probably buy an adjustable cable and quadrant or a firewall adjuster and quadrant and see where that gets me
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    State College, PA
    3,552
    ah ok never heard that trick ill give it a shot. thanks
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
  1. need transmission help
    By jasons_98gt in forum SN95-New Edge
    Last Post: 07-06-2014, 02:41 PM
  2. Replies: 13
    Last Post: 01-13-2014, 09:10 AM
  3. T-5 transmission
    By WHITEY7886 in forum Ford Parts
    Last Post: 06-16-2010, 11:28 PM
  4. C4 Transmission
    By Martin0660 in forum Ford Parts
    Last Post: 06-16-2010, 08:58 PM
  5. 5.4 Economy Troubles...
    By Wolfpack Speed in forum The Bar
    Last Post: 01-20-2009, 10:16 PM
