Results 1 to 18 of 18
Thread: 1986 Mustang Headlights
    2,247
    I'm not happy with how bright my lights are so i was looking into these..
    http://cgi.ebay.com/ebaymotors/79-84...Q5fAccessories
    http://cgi.ebay.com/ebaymotors/Musta...Q5fAccessories
    Does anyone have any input about them? Any pics of 4 eyes with projectors?
    Black
    2,247
    Black
    Dec 2008
    Natrona Heights PA
    3,056
    Those are wild lookin! I'd like to see how they look on a ride.
    Bu-2000-bash
    ALLSQUAD
    Steel City Muscle Cars
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
    2,247
    Quote Originally Posted by AdamantiumSilvr View Post
    I can't find any pics of them on a for eye but i haven't gave up yet!
    Black
    Dec 2008
    Natrona Heights PA
    3,056
    I haven't seen any either, hey maybe u could be the originator. Be the first one to try'em out!
    Bu-2000-bash
    ALLSQUAD
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
    2,247
    I'm gonna do a little research then maybe this paycheck i'll get 'em. Someones gotta be first, right?
    Black
    Quote Originally Posted by Shorty429 View Post
    Are you looking because you want to see better or for style??
    If you want to see better, you need to re-wire the headlights with relays. Right now the power to the lights goes through the headlight switch. By re wiring with relays, the power to the headlight comes directly from the battery, and only the signal comes from the switch. There are "kits" for this out there complete with harness (APC, etc) or it can be self wired.
    Do you still have the stock alternator? In most cases with the stocker you have to make a choice between lights and heat or defrost ;)
    In general, the quality of those lights is not very good. They are cheap for a reason.
    The only real way to get more light is with more / reliable voltage and the short comings of the early fox's are the wiring through the headlight switch, and alternator amperage.
    my .02 FWIW
    2,247
    I perfectly content with how the stock lights look. I just want to see better because i drive down 819 quite a lot and it's a dark a$$ road.
    Yes i still have the stock alternator. If I wanted brighter lights and heat/defrost is there a better one to buy?
    Black
    Castle Shannon
    1,276
    i concur. upgrade headlight wiring harness, relays... at the same time you can rewire them so all six lights stay on with HIs and fogs
    i' ve been looking for some lights like that also (actually bmw style angel eyes)... except TRUE HIDs. hella makes a nice setup but it's the larger (5x7?) lens. i'll lyk if i come across anything good :)
    PA Performance is the most straightforward way to upgrade. You can do the 130 amp 3G upgrade and be able to handle anything, but the 95 amp 3G is a little easier to fit (usually no bracket modifications). You will also need an adapter plug, and power wire plus there is wiring you must do. When I did my old Turbo Coupe (lots of power accesories) I did the 95 amp and was happy. I now have a 130 amp on my Capri, but maily becasue I came across the alternator cheap ;)
    http://www.paperformance.com/scripts...elname=Mustang
    You can accomplish the same thing with junk yard parts / part store rebuilds cheaper, but PA Perfromace has a great warranty, plus good tech support to make the conversion.
    2,247
    Do you know of anywhere where i could buy the glass to my fogs? they are both broken out so i have the marchal covers on.
    How much brighter does this make them?
    Black
    Keep in mind however, that a better/ stronger alternaor does not fix the basic issue with the headlights. Ford thought is wise to run the load for the lights through the headlight switch. If you up the amperage on your alternator, the light will get brighter, but the load on the light switch will also go up. Ultimately, to get bright lights you need to do the realy set-up for the lights too, and I would suggest it first.
    That fixes the lights, but they will still dim with heat / defrost because of the load on the alternator.
    The Marchel stuff goes for big $$$'s when it comes up on eBay. The hard core four eye guys are stupid crazy for those parts and buy them to hoard them.
    I have a few parts here (only one lense), and am really thinking about leaving the fog light set-up out of my car this winter when I swap to an aluminum front bumper.
    http://good-times.webshots.com/photo...66453426ncQdKg
    I really think the best solution is to shop for a light that looks similar / same and do a swap. The Marchels are stupid expensive right now.
    2,247
    would you be able to part with the 1 lens? if i remember correctly only 1 of my lenses is broken.
    Black
    Jan 2008
    Jefferson
    4,674
    im not a fan of those lights............
    State College, PA
    3,552
    same here... i didnt read this whole thread but i dont like the headlights in the first 2 posts.
    but hey its your car, if you like them buy them!
    2013 Mustang GT
    1999 Contour SVT
    2,247
    i'm just lookin for them to be brighter and i searched "projector headlights" they're not what i want, they have clear white ones that look almost stock but i've been told they're crap. Oh well, we'll see what happens
    Black
    Dec 2008
    Natrona Heights PA
    3,056
    True...
    ...that!!
    Bu-2000-bash
    ALLSQUAD
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
  1. Smoked 99-04 Mustang headlights (dark)
    By speedracer in forum Ford Vehicles
    Last Post: 03-19-2012, 05:58 PM
  2. 1986 Mustang Convertible
    By Donstang86 in forum The Bar
    Last Post: 04-04-2011, 05:16 PM
  3. F/S 99 stock mustang gt headlights
    By mildew in forum Ford Vehicles
    Last Post: 09-29-2009, 03:49 PM
  4. 2003 Mustang Headlights Fits 99-04 Mustang.
    By KeystoneJohnny in forum Ford Vehicles
    Last Post: 03-14-2009, 07:08 PM
  5. 99-04 mustang clear headlights
    By PSPstang in forum Ford Vehicles
    Last Post: 09-23-2008, 10:35 PM
