Results 1 to 12 of 12
Thread: Looking for a Service manual - 1995 Mustang
    Cheap SOB
    Baltimore, Maryland 21236
    288
    I was working on my new project car. Seems the previous owner didn't bother to hook up the radio when he stuck the stock unit back in the car. This has lead me to two issues:
    1. The antenna lead is broken off in the radio.
    2. The door speakers need to be re-installed.
    Now I know, I don't know how the antenna gets replaced. Also a quick cursory look (it was 3:30 am) and I didn't figure out how the door panels come off.
    Time to get a book. I have a Bentley Manual for my wife's Jetta and it has been useful when I needed it, but they only cover Mustang's up to 1993.
    Anybody have a suggestion for a good services manual for a 1995 Mustang? I was hoping for something a little more detailed then the Chilton / Hayes Manual.
    Senior Member 95DropTop's Avatar
    Gibsonia, PA
    323
    I found a mint condition Ford Shop Service Manual on eBay for 35.00 + 5 shipping. I it is an excellent book.
    I have seen the same for reasonable prices. Mine was a spare copy that was not used in the shop. I am the first guy getting it all greasy.
    03 Cobra redfire vert - 466 rwhp / 456 rwtq
    Mods: Bassani Mid Length Headers, X Pipe and Cat Back, Accufab Big Oval Throttle Body And Polished Inlet Plenium, 2.95 Reichard Ultra Grip Pulley, MotoBlue Auxiliary Idler Pulley Kit, LFP Double Pass Heat Exchanger, K&N FIPK, C&L intake Pipe, 3.73 Gears, MGW Shifter, Spec stage 2 clutch, Fidanza aluminum flywheel, MotoBlue Hard Launch Bar, Full Tilt Boogie Racing kit and H&R Race springs
    Cheap SOB
    288
    Quote Originally Posted by 95DropTop View Post
    The last two 'shop service manual on CD' I bought off of eBay were nothing more then a Chiltons Manual in PDF form. How do i make sure I get a same manual you have? Do you have a ISBN or a picture of it I can use to compare to?
    Quote Originally Posted by DRRummel View Post
    Helm is the publisher of all Ford manuals. They dont typically have ISBN numbers like normal book, rather just a publication number (assume Helm or Ford assigned). A quick search on Helm's site, they show the 95 manuals as out of stock, but you can get the part numbers there for verification. HTH
    http://www.helminc.com/helm/Result.a...CTHRG3T2F14LR2
    straight link to 95 Mustang shop manual..
    http://www.helminc.com/helm/product2...CTHRG3T2F14LR2
    If it's not Helm, it's not original ;)
    Gibsonia, PA
    323
    Like this one that is currently out there.
    http://cgi.ebay.com/ebaymotors/Ford-...sQ5fLiterature
    Senior Member scott5's Avatar
    NC
    10,168
    Cheap SOB
    288
    Quote Originally Posted by scott5 View Post
    thanks, but I am not looking for any Hanes or Chiltons.
    Cheap SOB
    288
    Anyone play with bittorrents? They seem a bit shaddy I don't know if I should load a torrent client. I am thinking it is a bad idea.
    http://www.3.8mustang.com/forum/showthread.php?t=225268
    Senior Member 85stang's Avatar
    Sep 2007
    irwin
    227
    if you want the antenna lead out drill a small pin hole in the center . put a screw in the hole and pull it out with pliers.
    85 mustang gt
    01 mustang
    06 F150
    65 t-bird (project)
    will:loco:
    Cheap SOB
    288
    Thanks. I bought that one. I also found that publication listed for 60.00, 72.00, 75.00, and 90.00 dollars. Thanks for pointing it out. That listing was the best price around.
    Cheap SOB
    288
    Quote Originally Posted by 85stang View Post
    I got Lucky. I visited a new Crazy Rays by my place for a casual stroll. They had one 1993 Fox3 and one 1998 SN-95 Convertible.
    On the SN-95 the radio, glove box and passenger fender were missing. The antenna lead was exposed but cut at the fender. I pulled it out and went to check out.
    It appears that a cut antenna wire is classified as a wire harness @ 5.98 a foot. But luck me, he was only going to charge me for 3 feet.
    Either way, I got lucky. I did not know there is a barrel connection behind the glove box. I pulled on the connector and split the cable in half, paid 5.98 for my one foot wire harness, and all is well again.
    Gibsonia, PA
    323
    You're welcome. It is a good book. You should like it.
  1. 1995 turbo mustang
    By SK@StreetLethal in forum Ford Vehicles
    Last Post: 10-22-2010, 05:49 PM
  2. 1995 Mustang GT
    By Milewsky80 in forum Ford Vehicles
    Last Post: 06-27-2009, 05:42 PM
  3. Who has a service manual for a 99 GT Mustang?
    By DRRummel in forum General Tech
    Last Post: 11-19-2007, 02:00 AM
  4. where to buy factory service manual...
    By 99 GT Coupe in forum The Bar
    Last Post: 09-16-2007, 10:55 PM
  5. 1995 Mustang 5.0
    By yeahloh95 in forum Ford Vehicles
    Last Post: 12-08-2006, 08:20 AM
