Results 1 to 8 of 8
Thread: Fuel question FOX
    Senior Member coralcoupe1993's Avatar
    Robinson
    3,842
    Fuel question FOX
    Before I start just replacing $hit......Some times my fuel pump doesnt run when I hit the key. I have to cycle it a few times before it build presure. I am going to change the pump because it is loud and probably has been in tank since 1990. Either way, sound like anything else? e.g. relay, ignition?
    87 GT
    93 Notch
    60 Country Sedan
    Fairlanes/Galaxies 59-68
    67 Contiental 4 door
    06 Powerstroke
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    That's kind of hard to say. It's probably the relay given the age. A pump generally runs or not. If you've ever run the car out of gas, that can damage the pump. Miles & age can do it too. Ignition has nothing to do with the pump. Pull the hose off of the regualtor & smell for gas. A sure sign of a bad regualtor.
    Mark Lowry
    Wolfpack Speed, Inc.
    4290 Campbells Run Rd
    Pittsburgh, PA 15205
    (412) 279-4902
    Senior Member lib88stang's Avatar
    LowHill
    2,679
    Ive had problems with relays before, its good to have a few spares just incase.
    Robinson
    3,842
    I just got back from a Christmas party at my friends house (has an 01 Cobra). I had him hit the key when I was by the trunk, it is running but very low. It takes 3 cycles of the key. Just a week fuel pump! I have a new 155 and fuel filter I will put in tomorow after xmas shopping!
    87 GT
    93 Notch
    60 Country Sedan
    06 Powerstroke
    Robinson
    3,842
    It was 100% the fuel pump. Looks like it was the stock Ford as well (155K miles). I put a 190 in, runs MUCH better. Its nice not hearing a fuel pump over the exhaust. I think I am still high from the gas fumes....
    87 GT
    93 Notch
    60 Country Sedan
    06 Powerstroke
    Mr. 331 N8Miller's Avatar
    Dec 2006
    Kingston, PA, USA
    239
    yeah, FP was my guess.
    did you replace with a stock pump?
    1986 GT:331, Edelbrock Vic Jr heads, Jay Allen custom cam, TFS R intake, 30# injectors, 75mm t-body, 80mm PRO-M, AFM Powerpipe, BBK 1 3/4 long tubes, BBK X pipe, 4.10s, 5 lug conversion, 99GT rims/Nitto DRs, PBR brakes, Lakewood 50/50s, Moroso rear drag springs, Sub frames, 2.5" cowl, Saleen spoiler
    Power of a low 12 second car, Traction of a high 14 second car!
    Robinson
    3,842
    Quote Originally Posted by N8Miller View Post
    No, I put a Walbro 190 LPH in. I just went for a ride (xmas shopping) and my engine temp is way down. Could this thing have been running lean enough to make my engine temp high??? It is truly much lower.
    87 GT
    93 Notch
    60 Country Sedan
    06 Powerstroke
    Member RUSH2112's Avatar
    Hopewell, PA
    754
    I replaced my fuel pump a couple months ago. It was the original stock pump. I put a 255 BBK (walbro) in and it is running great.
    Edelbrock Performer Heads, BBK Ceramic Long Tube Headers, BBK O/R H-Pipe, BBK Cold Air Intake, BBK Strut Tower Brace, Flowmaster American Thunder Cat-Back, FRPP King Cobra Clutch, FRPP 3.73 Gears, FRPP Chrome Cobra Upper/Lower Intake, FRPP Chrome Polished Valve Covers, Chrome Alternator, Ford B303 Cam, Holley Fuel Pressure Regulator, 70mm Edelbrock TB, 75mm Pro-M MAF, #24 Ford Injectors, Crane 1.7 Rockers
  1. question on fuel pressure
    By vitaleffects626 in forum General Tech
    Last Post: 05-05-2011, 10:04 PM
  2. Fox body fuel line question
    By White5.0 in forum Fox-SN95
    Last Post: 03-27-2011, 08:15 PM
  3. fuel pump question
    By PSPstang in forum General Tech
    Last Post: 10-15-2008, 10:45 PM
  4. Fuel Leak Problem/Question
    By RUSH2112 in forum General Tech
    Last Post: 03-28-2008, 07:41 PM
  5. fuel rail question - do i cut or what?
    By phillysrt4 in forum The Bar
    Last Post: 02-01-2008, 10:22 AM
