decided to keep the car and sell the motor and tranny. Combe has never seen the strip, break in time and maybe 20 street miles. Might consider trading some of the parts for a 302 5-speed combo. shipping is not included in the prices!
Shortblock: 84' Block .040, Cat 4.100 stroke internally balanced forged crank, Probe RPM Series forged H-beams with ARP 2000 bolts, SRP forged pistons (either 14.5 0r 19.5cc dish), Steel main girdle. $2700
Brodix Track 1 225 heads. No work, straight out of the box. Solid roller springs good to .700 lift, titamium retainers, 2.10 intake and 1.60 exhaust valves, guide plates and 7/16 studs. $1800
Comp Cams Solid Roller: .649 intake lift, .641 exhaust lift. 276 int. duration and 280 ex. duration. Have cam card. $200
Comp Cams Solid roller lifters: $200
Crower Steel Bodied Roller Rockers: 1.7 ratio with 7/16 poly locks (the long style for a rocker stud girdle) $200
Motorsport Victor Jr intake: Fits 9.5 deck, runners have been ported to a 1262 gasket but plenum is untouched, Clear coated. $150
Race Demon 950 Carb. $500
March Aluminum Polished Pullies: Have crand and water pump only. $50
MSD Billet Dist. for a 9.5 deck and is 3/4" taller to clear the victor jr. intake. Has bronze dist. gear and motorsport oil pump shaft. $225
Accufab 1 3/4" LT with 3" collector for a 9.5 deck and fits Brodix Track 1 heads. Wide bolt pattern. Dr. Gas-x x-pipe and dynomax round mufflers. Headers clear QA1 k-member, Accufab told me they would clear a stock k-member. $600
Canton 7qt Oil pan. Baffles on the side have been removed and front had been dinged to clear the steel main girdle. $150
Motorsport balancer Neutral balance, but any weight can be added to it. A little surface rust. $100
Transking built C4: Rated to 800hp. Case filled, rollerized, Transbrake, reverse manual valve body, SFI aluminum bellhousing, Scattershield, deep pan, 4000 stall converter, B&M trans cooler with 6AN lines, and tow SFI flexplates, one is neutral balance and the other is 28oz. $1500
Cheetah pro action shifter. Reverse pattern for a C4. Comes with new cable and mounting bracket. $150
Or save a few hundred and buy everything for $8000
Pm me or call Ryan 713-854-1955, Currently live in SE Ohio, but moving soon to Pittsburgh. Prices do not include shipping.
