Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: 2001 Pontiac Trans Am - built Twin Turbo LS1
    Spencerport, NY
    3,762
    Yes, I am putting my baby up for sale :( .... its a 2001 Pontiac Trans Am. This car is absolutely awesome. It has impressed/awe'd EVERY single person that has ever been in it. I spent over a year and a half building/completing the twin turbo kit while still leaving this car 100% street legal. I'm asking 23,900 OBO, which means I'm not getting back even close to half of what I have put into it - I thought I'd never sell, but I have other aspirations in life now.
    The car itself has just over 74,000 miles on it - but the engine, turbo kit, clutch, rear end, etc all have less than 1,200 miles on them. The black leather interior is in incredible condition and the black exterior is amazing as well.
    The car is meticulously maintained. Only the very top end oils and lubricants have been used in this car!
    The car made 698hp and 706tq to the rear wheels on 93 octane PUMP GAS. All that while on an extremely conservative 13.5psi, 11.0:1 A/F ratio, 12* of WOT timing, spraying 50/50 meth/water. The engine is a fully forged LS1 motor (348ci) that was built to handle far more horsepower than the car is currently pumping out. I had it tuned soo conservative because I didn't want to take the chance of a misfortunate bad tank of gas or something!
    Its hard to describe in words just how awesome this car is - you have to see/feel it to believe it. It looks absolutely amazing, and runs TOP NOTCH! Traction? guys with 200rwhp less complain about not being able to get traction, but this car puts all 700rwhp to the ground - its quite a feeling. I have no traction issues at all, as long as the temperature is above 60* outside - not even in first gear.
    Below is a list of the mods done to the car. There may be some missing, but I think this pretty well details just how well built this car was and how no expense was spared to make this a reliable, and 100% streetable monster!! If you want to rule the streets, this is your car! If you have ANY questions whatsoever, please feel free to ask. I have lots of pictures and also have added a couple videos. Serious inquiries will include a response with my phone number to discuss anything you may want to know.
    The car at idle - sounds extremely healthy and the cam gives a nice lope!
    http://video.google.com/videoplay?do...09951877&hl=en
    A few small revs - the turbos make themselves well known, especially driving down the road
    http://video.google.com/videoplay?do...41263549&hl=en
    Modifications
    Engine:
    • Stock aluminum block LS1 (5.7L), bored .010 over (348 ci)
    • Polished crank and fully balanced rotating assembly
    • -16cc Mahle forged pistons w/ file-to-fit rings (filed for blown/turbo application)
    • Eagle 4340 forged H-beam connecting rods w/ ARP L19 bolts
    • Clevite bearings throughout
    • Ported and polished 5.3 heads (heads/valves have 3000 miles)
    • ARP head studs
    • GM MLS head gaskets
    • Comp Cams 220/224 .564/.568 115 lsa, custom turbo grind cam – custom grind for mid-range torque
    • LS2 timing chain
    • LS6 ported oil pump
    • LS6 intake manifold
    • Patriot Performance Gold dual springs, with titanium locks and retainers
    • LS7 lifters
    • NGK BP7EFS spark plugs
    • Full A/C, heater, etc.
    Turbo Kit:
    • 58mm Precision turbos (2) – T4
    • Custom built, thick walled stainless steel headers
    • 3" Stainless steel downpipes, connecting into 4" stainless exhaust, then exiting to dual/dual 3" stainless tips
    • Stainless steel charge piping
    • Very large 2in – 1out air-to-air intercooler (polished)
    • 38mm Tial wastegates (2)
    • 50mm Tial Blow-off valve
    • Slowboy Racing manual boost controller
    Fuel System:
    • Twin 255lb Walbro fuel pumps (2)
    • Custom pressed steel-braided fuel lines
    • Aeromotive fuel pressure regulator
    • Aeromotive fuel rails
    • Seimens/Motron 60# high-impedance fuel injectors (flow-matched)
    • Mallory fuel gauge isolator
    • Snow Performance Boost Cooler methanol injection kit
    Supporting Mods:
    • T56 6-speed manual transmission
    • Spec Stage 3+ clutch
    • Custom aluminum driveshaft
    • Moser 12-bolt rear end
    • Detroit True-trac differential w/ 3.08 gear ratio
    • Mickey Thompson ET Street Radials – 255/50R16
    • A-pillar 3 gauge pod – wideband o2 (a/f), fuel (psi) and boost/vacuum (psi/hg)
    • Custom short-throw shifter
    • Custom "in-floor" subframe connectors (2"x4")
    • BMR tubular K-member
    • Polyurethane motor mounts
    • US Exotics Superhawk fiberglass hood (1 of 500 made)
    • Custom 3-bar speed density tune by Nate @ TPG Tuning
    **This car made 697.56hp and 706.16ft lbs of torque at the rear wheels on only 13.5 psi of boost. This was also at an air/fuel ratio of 11.0:1 and 12* of WOT timing.
    Asking 23,900 OBO. Trades will be considered, but trade + cash must be of equivalent value to what I'm willing to accept. I have lots of pics, but my laptop crashed 2 days ago and I don't have access to Photobucket here at work. So here are a few that I have on fquick
    http://www.fquick.com/garages/viewga...d=1&carid=4832
    2015 Corvette Z06
    - Shark Grey / Kalahari
    Ligonier, PA
    6,365
    bump for this car.....it will make you pee your pants....I did.
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    2,145
    Oh no! The Dark side is calling me! It said...sell the Cobra and come back home.
    Guys this car is a monster! I was heading up 79 and this thing blew past me like I was driving a Neon or something. I hate to see him sell it and I hope it goes to a good home with some one that will respect the power it has.
    Stock 03 Cobra Vroom Vroom!!
    never stock biminiLX's Avatar
    Beaver
    2,406
    Good luck Bish.
    I didn't pee my pants, but I enjoyed the ride :)
    Spencerport, NY
    3,762
    Quote Originally Posted by 2001GTTT View Post
    Good luck Bish.
    thanks guys!
    2015 Corvette Z06
    Have seen and heard this beast. Its beyond words can describe... If anyone is looking for a nice fast car this thing is it!
    Member travj31's Avatar
    Uniontown
    1,688
    why are you selling? getting out of cars, new porject, what? never seen the car but sounds badass... goodluck with the sale
    Spencerport, NY
    3,762
    Quote Originally Posted by travj31 View Post
    I'm selling because I just have too much going on and don't get to enjoy it enough. Like the ad says, I only have 1,200 miles +/- on the car. It doesn't just sit around and rot.. I drive it probably once a week, but it'll usually be to go to dinner with my g/f in Robinson or something - which is a whopping 20 mins away. So that's why it doesnt' get many miles. I always said that no matter what car I had, i'd drive it A LOT, which is why i made this thing 100% street legal - i expected to drive it a lot. But with my job, professional exams, and other things going on, I just don't have all the time I used to have. :(
    Plus, i'm in the market to buy a home, and even though i can afford both, it would be nice to have that extra money in my pocket each month, instead of putting it into something that doesnt leave the garage more than once or twice a week.
    2015 Corvette Z06
    Spencerport, NY
    3,762
    u know you want it buddy!
    2015 Corvette Z06
    text me about it
    In a Time Machine
    3,361
    __________________
    I got a house for sale
    Spencerport, NY
    3,762
    I saw that - thanks, but the location would be a crazy long commute to work for me and i'm really not wanting a split-entry. Thanks though!
    2015 Corvette Z06
    Spencerport, NY
    3,762
    bump....
    I'm leaving in 30 mins and will be gone for the weekend. If you would like to discuss anything with the car, please PM 2001GTTT and get my phone number off of him.
    Clark, do you mind giving out my # to anyone who is interested? I just don't want to post it on the wide open Inter-wide-web.
    Thanks !
    2015 Corvette Z06
    Ligonier, PA
    6,365
    bump....
    Thanks !
    no problem at all man.
    1991 BMW 325iX
    1978 Ford F150
    Spencerport, NY
    3,762
    bump...
    2015 Corvette Z06
    Spencerport, NY
    3,762
    Ttt....
    Interior Pics
    2015 Corvette Z06
    Spencerport, NY
    3,762
    bump.... tell all ur friends!
    2015 Corvette Z06
    Senior Member SUPERDUTY's Avatar
    Jan 2008
    181
    thats one sick car
    2007 Hummer H2
    2006 Hummer H1 ALPHA
    Ford guy turned GM
    Spencerport, NY
    3,762
    Thanks guys... there seems to be a lot of interest, but a lot of it is from out of state, so i'm not taking it too seriously until someone actually brings the $
    2015 Corvette Z06
    Spencerport, NY
    3,762
    Bump...
    2015 Corvette Z06
  1. 2000 Trans Am WS6 LS1 RamAir
    Last Post: 12-05-2011, 03:39 PM
  2. 2001 pontiac grand prix
    By 89stang in forum Ford Vehicles
    Last Post: 11-10-2010, 12:45 PM
  3. 1999 Pontiac Trans Am
    Last Post: 06-15-2007, 01:19 PM
