Results 1 to 12 of 12
Thread: Trick Flow kit Problems HELP
    I'll start by saying I have a 1987 mustang gt. It is a 5.0 and it was an auto. I converted it to a 5 speed.
    Ok Im going to try to list everything that is done! THis is what I have
    trick flow street heat kit from summit!
    I have converted it to maf by changning computer and wiring harness.
    I bought a 255lph fuel pump
    24 lb injectors
    msd replacement coil
    msd cap and rotor
    new plugs and wires
    I got my maf sensor from the guy with the computer and wiring harness. It was suppose to be recalb. for 24 lb injectors.
    The car idles ok and sometimes stalls. (think that has to do with speed sensor that isnt hooked into the computer yet) It reves fine and sounds strong.
    Here is the problem.... When I take it down the road it runs good inside 2 grand but after that it cuts out bad!
    I unplugged the maf and it straighten it up a decent amount. So tomorrow Im going to test the meter or sensor with my friends one that is for sure for a 24lb injector.
    I was told that maybe a map sensor could make a difference from 87 to a maf yr. any comments on what is happening or any common problems or answers! Thanks for your help
    Member silvernotch's Avatar
    Bethel Park
    664
    my nephew's car did the same thing. The mass air meter was bad.map sensor should not have the vacuum line hooked up.
    Quote Originally Posted by silvernotch View Post
    Yep.
    ok we are going to try that tomorrow and fine out if thats the problem
    out in the woods
    4,948
    yea when you go mass air your sposa remove the vacuum line off the map sensor in 87-88 cars. make sure you plug that line
    yeah I'm pretty sure that is done. I will double check it tomorrow thanks everyone
    Well I ran my test... maf is not the problem or the computer.. The fuel filter was plugged we changed it but still not the problem!! soooo here is a possible problem! in the wiring harness. I am using the 87 (non mass air) engine harness. Could that be my problem? I notice that my oil pressure wire is now my temp and my temp wire is unplugged because it doesnt power the temp gauge or oil pressure gauge! Let me know what you think
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    The EEC-IV uses the coolant temperature sensor located in the coolant rail. This is used to add fuel or trim timing. Are you speaking about the sensor on the right located on the coolant rail to the heater or the one on the drivers side in the front of the intake manifold? The one in the intake is only used for the factory gauge, not the FI.
    Mark Lowry
    Sep 2007
    Homestead
    780
    The line does NOT get plugged. It should be open to the atmosphere.
    Member torqueboxer's Avatar
    white oak, pa
    638
    If your filter was clogged its possible the feed line from the pump to the top of the fuel hat is ripped spraying fuel inside the fuel tank instead of the fuel lines>>>enough volume at idle, not enough to get the car really rollin.
    Caledonia, Ontario
    620
    Quote Originally Posted by frankstang View Post
    To be crystal clear, plug the vacuum line & let the sensor open to the atmosphere.
    Mark Lowry
    Fort Eustis, VA
    525
    Quote Originally Posted by scottyko88 View Post
    The 87 Harness is fine, depends on how the mass air conversion was done. As long as you installed the mass air wires in the proper positions of the 60 pin connector and moved the ones that need to be moved then the harness should be fine.
    here's a link to a good tech article on how to do the conversion and what pins to switch and where to place the mass air wires.
    http://www.popsracing.com/tech/mafconversion.pdf
    86 Notch New Project
  1. trick flow intakes
    By stangfever in forum Ford Parts
    Last Post: 11-19-2011, 02:43 PM
  2. FS: Trick Flow Billet Oil Fill Kit
    Last Post: 03-31-2011, 10:31 PM
  3. haveing problems with trick flow intake
    By vitaleffects626 in forum Fox-SN95
    Last Post: 04-06-2010, 06:55 PM
  4. trick flow streetburner?
    By Gray 5.0 in forum Fox-SN95
    Last Post: 10-08-2009, 05:04 PM
  5. Replies: 2
    Last Post: 07-07-2008, 12:27 AM
