Results 1 to 3 of 3
Thread: SBF Engine Parts, aftermarket and OEM
    Intake Manifold - Mass-Flow Port EFI with OEM injectors, sensors, and fuel lines
    Nice shape, low usage from PO. Worked with factory EEC ECM.
    I never used it since switched to different type of manifold.
    $250
    Factory Oil Pan and pickup tube for foxbody and I assume SN95.
    Excellent shape just wouldn't work for my application otherwise I would have use it.
    $50
    Factory oil dipstick tube and dipstick for roller blocks
    $10
    Factory 50oz 302 rotating assembly (approx 1990 vintage) - OEM never touched...original std/std brgs, factory TRW forged pistons...etc.
    1 cyl pushed an oil ring causing some cyl scratching so I had to overbore - the piston itself seems perfectly good to re-ring and reuse all of it in a std bore block.
    $150
    Scat 28oz imbalance 157tooth flexplate brand new in box - $50
    Pioneer? 50oz imbalance 4 bolt damper with timing marks for driver side and pass side indicators - $50
    Nearly new power steering pump and bracket - $50
    Nice 3G alternator - $50
    EFI timing cover and new water pump - $50
    FRPP F Cam (low miles) and factory hyd roller followers in nice shape - $100
    Cast aluminum COBRA oval air cleaner with K&N Filter - $100
    Parts located near Bentleyville Washington County 15314
    - John
    PM sent for timng chain cover & waterpump.
    South Hills, PA
    4,052
    If u need a water pump i have 2 like new store brands. Free
