Results 1 to 4 of 4
Thread: 5.0 drivetrain for sale
    Uniontown, PA
    276
    5.0 HO drivetrain engine tranny shorty headers, rad shroud and overflow tank and engine accessories - complete engine and tranny pulled from running driving 91 5.0 with around 100k on it. The car ran solid, no issues, no using fluids, typical 302 and T5 leaks from an almost 30 year old uncracked motor. The following are the specs of the engine and tranny and accessories.
    302 HO COMPLETE engine
    Stock block with stock heads with following mods(mods have 500 miles on them)
    B303 camshaft
    Ford Performance Parts Hydraulic Roller Lifters M-6500-R302
    Summit G6620 timing gear and chain set
    Trick flow TFS 2500100 camshaft spring kit
    Water pump was changed with above parts
    Aeromotive Adjustable Fuel Pressure Regulator stock ford fuel lines
    24 lb injectors
    PA performance satin black alternator
    65 MM Professional Products Throttle Body
    76MM C&L meter with match 24lb tube
    BBK Cold air intake
    Stock cam, gears, chain, throttle body and injectors available if there is a need for them for a small fee.
    I believe the car has some or maybe a combo of underdrive pullies on it as well.
    All accessories on the front of the engine including stock distributor cap and rotor, alternator power steering pump accessory pullies and harmonic balancer. No AC condensor however the car did have AC on it and I have a used compressor (don't know if it works)and you would have to buy lines or buy an AC delete kit.
    Stock T5 tranny with steel bearing retainer
    Steeda Tri Ax shifter
    Stage 2 Exedy Clutch (500 miles)
    Tranny shifted as smooth as any other 100k T5. No missing gears or gear popping or grinding
    1 ⅝ ceramic coat BBK full length headers
    2 ½ BBK H pipe
    Typical wear exhaust is about 8 years old
    I am sure that I am forgetting something. I can send any pics you want or you are welcome to come and see the parts as well. I am sure that I have a video of the vehicle running somewhere too. If you have any questions or I am omitting anything and you need information just send me a text or call.
    I will separate engine, tranny from each other but I will not piece meal the engine or any of its mods.
    If any of the parts are sold I will update the post
    2200 or reasonable offers will be entertained.
    724 366 5565
    http://www.fquick.com/celeste
    1989 Mustang GT 663 RWHP
    1991 Strawberry Notch
    1992 Calypso LX
    MM&FF Article
    5.0 Article
    Uniontown, PA
    276
    Long tubes and H pipe have been sold!
    Have a set of shorty BBK headers that I will include
    1992 Calypso LX
    MM&FF Article
    5.0 Article
    Uniontown, PA
    276
    forgot to update price without headers and H pipe.....2200 or reasonable offers, shorty headers included.
    CPU and harness available if needed for additional charge.
    1992 Calypso LX
    MM&FF Article
    5.0 Article
    Uniontown, PA
    276
    Sold
    1992 Calypso LX
    MM&FF Article
    5.0 Article
