Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
Thread: Fall track rental personal bests?
  1. #21
    Junior Member
    Oct 2018
    Butler, PA
    1
    My hooptey 89 camaro clicked off an 11.68 @ 115 which is my personal best with the car. Managed a 1.5 60 foot one time before I grenaded the rear end. It was a fun time for sure.
  2. #22
    2,103
    I ran my first 10 last track rental and my first 9 this time around, I like this trend! Sadly no plans for an 8 next year, lol
  3. #23
    Feb 2015
    825
    Eh, I pretty much have enough data to say it isn't going to do much better without 1) like 2# more boost or 2) a much better 60' ... The boost is there but I've never looked at fuel at that level, running out of fuel even for a millisecond = melted shit ... the 60' needs gear, we threw more RPM at it every pass and it never improved 60' time ... Even If I could tag a stab at the fuel, if it made much more power its going to drive through what's left of the clutch. Car was put away running and I'm very happy with what it's done all season. I have said numerous times I don't really care if it ever goes 9.99 other than to say it's been done. My safety stuff is good to 10.00 and I've gone there.
    How much boost you cranking on this beast to get down there? I believe the limitation to this engine is the head design, correct? Cant force enough air through it?
    90 TSi AWD Auto - 10.96@124.93
  4. #24
    7,568
    This weekend was 36# .... turbo is sized to go 40#, but with really good air and more boost it would be risky to turn it up further. I logged a 10.20 pass and fuel was still safe, but moved above my target line.
    The head is surely a dinosaur, and mine is a ported factory head. The guys going much faster than me are all on aftermarket aluminum heads. There are a lot of issues with those, and it's a choice we need to make between a 60's designed port and chamber versus a slightly better port and chamber in a head made of peanut butter (soft aluminum). The aftermarket heads was made for NA applications (circle track stuff) and are a pain to seal at my cylinder pressures.
    The limitations are many, the head is old design, single heavy valves with only so much room for lift and spring pressure, limited how far we can go on cam blanks, etc ... then there is the self inflicted stuff like a header made of schedule 40 pipe ells, etc.
    Broadly, it's an old design, low reving package that's just stout enough to take abuse.
    84 Capri RS Turbo -Best 1/8th - 6.42@107, Best 1/4 - 10.09@134... Only a 4 banger
  5. #25
    3,346
    still so much good d/a left though I really need to get my 2012 Coyote to the track or my blown fox.
    That sounds like a good idea!
  6. #26
    7,568
    still so much good d/a left though. I should talk about racing more but not actually do it
    sounds like a plan
  7. #27
    4,819
    i did have a pb in the focus of 14.2@101 hoping for 13s when I run it next year
    17 triple yellow focus ST2
  8. #28
    3,346
    What does a full bolt on ST typically e.t.?
  9. #29
    11,079
    Depends on if you launch off idle or not.
  10. #30
    4,819
    14.2 is right in line for my mods I am not quiet full bolt ons yet , intercooler is showing up today , it will take sticky tires to get into the 13s at my power level
  11. #31
    Mar 2009
    South Hills & Washington
    843
    Are you tuned yet? I just finished up a protune with Brian @ jst performance on my RS. I would definitely recommend him if you're looking for a tuner.
  12. #32
    3,346
  13. #33
    3,346
    Look out!
  14. #34
    4,819
    Quote Originally Posted by 1320goat View Post
    i have an email tune from unleashed heard good things about them they do reply very quickly but i have a check engine light on now from no cat ??? does jst use sct ?
  15. #35
    Mar 2009
    843
    I believe he uses both sct as well as Cobb ap. I use an Accessport.
  16. #36
    Lots of cool cars at the rental. I only got to watch from the tower. Anyone get pics or more vids to share? I dig AMCs, bad quality pic from up in my little box behind the computer
    ChuckT
    Sponsored by
    Millerstown Pic A Part
  17. #37
    No idea why it’s sideways. Shrug. Jeff and Brian
    ChuckT
    Sponsored by
