Page 1 of 4 123 ... LastLast
Results 1 to 20 of 63
Thread: Fiero part 3 - 3lbs per horsepower?
    likes turbos Tom's Avatar
    White Oak
    915
    I decided to make a new thread because the images on the old thread stopped working. JeffreyCole, Dewayne and I will be trying to finish up the car on Saturdays this summer.
    The current state of the car is that the mechanical aspects are done, it needs wired, plummed, tuned and dipped (we also need to figure out the new trans controller). It's at Jeff's house now because my garage is a mess.
    I'm thinking we might try to lighten it some too...
    1987 Fiero GT
    Old: 10.7@132mph - PTE6262, L67, ZZP4T65eHD - 2750 Stall - stock heads - 93
    In Progress: PTE6466, L67, EP4T80e - 3000 Stall, ZZP Heads, e85
    Feb 2015
    879
    Summer?
    Try spring. Lol. It'll be on the track during the summer.
    90 TSi AWD Auto - 10.96@124.93
    11,261
    Aright fellas! That’s one neat little ride. Glad you’re back on track!
    Oct 2010
    Carmichaels
    211
    Way to go guys
    4,458
    What happened to the shop that was building it?
    White Oak
    915
    The main guy working on it got married and has a kid on the way and I think ran out of time, It wasn't a real shop, just some guys that work on them in their spare time. They got all the done that I would have trouble with, it just sat for a long time. We will get it sorted out pretty easily from here though.
    1987 Fiero GT
    11,261
    This car is going to be nuts. Can’t wait to see it!
    Oct 2010
    Carmichaels
    211
    3lbs / hp sounds like fun Mine is double that
    4,458
    Quote Originally Posted by Tom View Post
    The main guy working on it got married and has a kid on the way and I think ran out of time,.
    pfffffffftttttttt...........no reason to THINK he ran out of time.....married plus kid = NO FREE TIME GURAUNTEED
    LOL
    glad to see this is back on the front burner....always liked this platform for the FLD's.
    Feb 2015
    879
    7,818
    I keep these around because I have a flammable EMS
    White Oak
    915
    First saturday was more of a planning day with a bit of beer...
    We got the wiring harness removed:
    Took some notes:
    and removed a bunch of old AC stuff from below the car and the front in order to re-route the a2w lines.
    We made decent progress, next Fiero day is May 12th with the plan to finish plumbing fuel system, and wiring all other other non-harness stuff (a2w pump, surge pumps, water pump, oil scavenge pump)
    1987 Fiero GT
    White Oak
    915
    It's no longer pink...
    oh.. I remember why we dipped it pink...
    1987 Fiero GT
    Feb 2015
    879
    Hahahahahaha
    11,261
    Much better!!!!!!
    Feb 2015
    879
    I feel like this thread needs an update with all the work we have done on this thing as of late.
    White Oak
    915
    We got a lot done, but I didn't take pictures.
    turbo:
    turbo oil drain line is almost done, new oil pan bung is done, remounted the turbowerx pump, turbo oil inlet is done, pump still needs wired
    Heater/AC:
    All gone, new front "firewall" built and put in, deleted AC lines and heater core lines
    Trans:
    trans pressure gauge hooked up, cooler lines almost done (one side is done, other is waiting for a fitting, decided to eliminate the range and NSS switch, found the trans cable retainer (super rare on these),most of the trans is wired, Torque Converter bolts ready to go in, mounted TCU in cab
    Fuel:
    Pretty close to being done, just some wiring
    Radio:
    Deleted
    Fancy:
    Retrimmed the trunk cutout
    Motor:
    Adjusted the Alternator bracket, beat on a motor mount for a few hours
    Things left:
    Reinstall intercooler and intake pipes
    rework exhaust
    brakes (new front pads, reconnect lines)
    check front wheel bearings, there is a lot of play in them for some reason
    bypass NSS and range switch
    wire fuel pumps (hobb switch, relays)
    power for tcu
    ecu -> tcu connections
    put in adapter fitting for rear trans cooler line
    put in tq converter bolts
    rear end lift kit
    map sensor
    re-install engine harness, change some things for the water pumps and turbo oil pump
    We are probably 2-3 more full days of working on it to get it started, which will be around a month and a half because we only work on it on saturdays and are going to miss 2 of the next 3.
    1987 Fiero GT
    11,261
    I think it would be EPIC to see the Fiero and Quadrabird line up at Keystone!
    White Oak
    915
    is the quadrabird's wrap flame retardant?
    1987 Fiero GT
    Oct 2010
    Carmichaels
    211
    That could be a problem
