Results 1 to 20 of 28
Thread: Need 100 Octane Unleaded ASAP - close to Pgh Airport area a plus...
    10,698
    I need 5-10 gallons of 100 octane unleaded gas ASAP. As close to Moon Township ( near Pgh Airport ) is a plus. Whatever info you have is appreciated - address - station name - whatever. Thanks fellas.
    2,044
    There's a motorcycle shop on Campbell's Run where you can get some. Also a gas station near Corliss tunnel sells it at the pump
    Cat Delete Pipes, One Piece Drive Shaft, Diff Brace, 305/35/20 555R's
    08 STI
    Full bolt ons
    South Hills
    2,808
    On Corliss Street is Schuler's, I think it is Leaded there.
    10,698
    Thanks guys. Heading to the shop on Campbells Run during lunch to see if they have it.
    In the future I will probably run down to Pitt Race and fill up a few cans from the pump.
    10,698
    Go figure - shop on Campbells Run doesn't carry it anymore. Hopefully the Honda shop in Moon has it - will find out tomorrow - closed on Wednesdays! Ugh!
    Oct 2010
    Carmichaels
    140
    I have 10 gal Sunoco if you want to come to Carmichaels $62/5 gal
    10,698
    Quote Originally Posted by mgtf289 View Post
    Thanks very much Mr. Ross. Unfortunately you are 60+ miles from me. If the local bike shop doesn't work out tomorrow I think I'll be heading to PittRace on Friday - about 35 miles and they're open until 8pm. $9.20 a gallon for 100 octane unleaded - and I'm hoping their gas is pretty fresh. Fingers crossed.
    There is a Sunoco station at the Center exit of 376. They may have some
    10,698
    Thanks guys. Honda shop near me didn't have gas so I drove to PittRace tonight for 10 gallons. $9.20 /gallon
    7,313
    I’m not sure what you need it for, but at 100 octane no lead I would just start keeping Torco around and make your own when you need it
    84 Capri RS Turbo - Best 60 ' - 1.35, Best 1/8th - 6.48@104.74, Best 1/4 - 10.20@133.95 ... Only a 4 banger
    10,698
    I just need this to run thru the '14. Logs show some knock sensor activity during WOT on the factory tune. Going to run 5 gallons of the 100 thru it and log again to see if the knock sensor activity goes away. Apparently the 93 octane in my area sucks balls - even Sunoco.
    Bob - where do you get the Torco and what could I expect to pay?
    7,313
    Best option for Torco believe it or not is eBay directly from them ... cost depends on quantity but figure $20 a quart shipped if you buy the 6 pack of quarts.
    10 gallons of 93 @ $3.00/gallon is $30 then add $20 a quart for a total of $50 to make 10 gallons of 103 unleaded.
    the upside is that is on demand, add it when you need it. Look at a mixing chart, I suspect for all you drive it, it might be reasonable to add a quart every fill up to something like 96-97 depending on tank size.
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,397
    I think Purvis Bros in Mars has 100 octane, but that's not exactly close to you.
    Jan 2011
    Allison Park, Pa.
    232
    Purvis Bros. has 110.
    1988 Mustang 408 W. All Motor 10:28 @ 131 mph.
    10,698
    Thanks Bob - that Torco sounds good to me - having it when I need it is a big plus.
    About Purvis - they don't carry 100 unleaded but can order it. But...they only order on Tuesday and it comes in on Thursday...and they only order if they have enough people wanting it. So no guarantee there.
    This is for my '14 so the 110 leaded is a no-go. Even my '66 runs unleaded which is nice. I can stock up on Torco and cover both cars.
    Are any of you guys with newer cars having issues with your local 93 being shit? I know Mark and Chris have. Mark went to E85 but that's not an option for me due to weak supply around me. What are you others doing - just running the 93 and letting the knock sensors pull timing? I doubt you all are going the Torco route on a daily basis.
    U.S. Citizen 86GT's Avatar
    Sep 2011
    Monroeville
    205
    It looks like Walmart has it for $139.95 shipped
    for a 6 pack of 32 oz.
    Black Bess : n/a 331 stockblock, T56 magnum, 379hp 382tq
    Best pass at Keystone 11.86@117.43
    Rodeheaver's Hot Rod Shop
    15 W. Cross Ave.
    Masontown Pa. 15461
    724-737-5088
    www.RodeheaversHotRod.com
    charleroi
    410
    What about 100ll avgas? Is that an option or no?
    Oct 2010
    Carmichaels
    140
    Av gas has way to much additives. My gas man had fits when I mentioned using it
    10,698
    AV gas - I've used that before - airplane fuel right? I think 93 mixed with Torco is probably the same net cost? Plus as was said I think AV has other stuff in it.
    10,698
    Is this what you're talking about Bob?
