Results 1 to 6 of 6
Thread: Looking for a electrical short hunter
    Senior Member 01cobra's Avatar
    Sep 2007
    131
    1989 mustang, no dome or under dash lighting & nothing in the rear hatch either. #8 in the fuse box is hot all the time. It has a 15amp fuse & blows right in your hand when installing. I'm no good with electrical problems, so i looking for a electric genius. Thanks! Fran
    Brookline
    2,897
    Got an overload somewhere or open circuit. Check under the fuse box for any corrosion anywhere? I'm sure you can find a wiring diagram online somewhere, then just start tracing wires.
    make sure your grounds are good
    Sep 2007
    131
    Have a wiring diagram, but that don't help. #8 fuse is light green with yellow. dome light, underdash lights & power mirrors, glove box light & rear hatch light.
    Member PotBellyPaul's Avatar
    May 2016
    Earth
    32
    Where are you located at?
    Sep 2007
    131
    Butler, pa
